WiFI extending question
3,682
Buy a Kubota Excavator and dig a trench and hardwire it. If that doesn’t work, buy a Kubota Skid-Steer and fill the trench in. 😜
5,860
while the spec is 100m(330'+-), you can get 450' depending on who designed the interface circuitry.
since there's already 120 in the trench, a pair of PLM ( Power Line Modems) would be the most secure option.
if you go wireless,be sure to change ALL the passwords( 2 or 3 ) on every device. Kinda interesting looking though others doorbell cameras, baby monitors, etc.....
58Ford
BX23s, LA340, BT603, RCR1248, PFL1242, STB1072
Jan 1, 2022
248
206
SW Washington
Line of sight? Yes if thats what that means.
Yep sorry, line of site. I use (as others mentioned) the Ubiquiti products and they have LOS products you can install yourself. jchonline has given you great info and I would likely do the same if I was you. My neighbor currently uses the same setup for his shop/house. There are other options like running POE power over Ethernet and also range extenders. I have the range extenders on our property and I am usually just frustrated with them. LOS works great if you have that option. Just have to point the 2 devices at each other.
Apparently (so the story goes) there’s a banker on the East Coast that owns a home on an island. The island has no internet but He has LOS from his office. This is how he gets his internet 😉.
Jchonline
599
Red Feather Lakes, CO
I haven't heard of that requirement before. Mine are on different circuits, same panel. No issues.
YMMV
It depends on the device. I bought a few off of Amazon awhile back and neither of them worked on a different circuit.
aaluck
Oct 9, 2019
984
836
Snowdoun, AL
You seem very knowledgable. Thanks for the advice. Do you know if the extender in #25 will work with the EERO system.
Jchonline
599
That looks promising. Do you know if this would work with the EERO setup? Would you just use the ethernet port on the EERO and connect it that way?
The only way a repeater works if if you have it in an area where you have a very strong wifi signal, and can repeat that strong signal out.
What you dont want is to add a repeater at the edge of your current wifi coverage area...because then you are just repeating that poorer coverage.
If you are plugging something up to the ethernet port on the EERO just add another access point. A repeater like the above is useless.
Antennas really dont make a ton of difference. Wifi signal can only go so far and degrades significantly with distance.
Here is an example of what I have setup. It is 145m (475 feet) from the top right building to the AC Mesh Pro spot. You can see the circle around the AC Mesh Pro (which is a very powerful access point)...it gets nowhere near adequately covering the distance. This is why you need PtP for these long runs. If you want to do it right this is the way.
aaluck
Oct 9, 2019
984
836
Snowdoun, AL
Thank you very much. So with the PtP I would need another EERO at the end of the point (at the gate) to turn that back to a useable WiFI signal? Sorry, I'm not too bright.
Jchonline
599
Correct. YOu would plug that EERO into the LAN port on your PtP antenna That EERO would communicate back to your EERO router or parent mesh device.
A PtP antenna if you have good Line of Sight: https://store.ui.com/collections/operator-airmax-devices/products/nanobeam-5ac-gen2
Remember you will need to run an ethernet cable from your EERO router to this PtP antenna.
So EERO router at house <--> PtP antenna A at house <--> PtP antenna B at gate <--> EERO access point at gate.
You can beam these PtP antennas through a window if that helps...but it degrades the signal considerably. For the distance you have it should still be fine. The best is to mount it externally...but I dont do that.
Here is one from my office in the house to my shop. Notice I trimmed branches on trees to give clear line of sight. One on shop is mounted externally. Red arrow.
aaluck
Oct 9, 2019
984
836
Snowdoun, AL
Very interesting. Thank you for sharing your knowledge.
Mark_BX25D
Bx25D
Jul 19, 2020
1,924
1,408
Bingo. A lot of people think they can take a weak signal and amplify it and life will be good.
At that point you are just amplifying noise.
