WiFI extending question
aaluck
Oct 9, 2019
984
836
Snowdoun, AL
I currently have five EEROs at the house. They cover the house without an issue. The problem I have is my gate is about 500-600 feet from the house. Although I do get a usable signal to the the gate for the opener and Ring doorbell, I would like to improve upon that to make it more reliable and sound.
So for all of you IT guys.....
Is there a 'directional' extender that I can use WITH the existing EEROs?
Is there a tip or trick I can use to get a better signal?
Thanks for any input.
6,016
do you have an electrical supply (outlet) nearer to your gate? If so, I've had great luck with powerline adaptors. They use your electrical wiring to take the place of ethernet connections. They've been very reliable for me.
Daferris
LX2610
Nov 23, 2021
486
411
Mid-Michigan
I use Ubiquiti stuff at home. It works really well. They have a few options that might be helpful...
A pair of Nano's to shoot out to your gate. I use them at one of the Race Tracks I do T&S at for the starter station and for the printer over at driver info.
If the stuff at the gate has enough transmit power you could also try a LR access point.
If you have power at the gate then power line adapters could be an option.
Code
l3301, fel, lp boxblade, 12" lp auger, lp bush hog, z421 zt, lawnvac leaf vac
Dec 19, 2020
146
120
Southwest Idaho
I use tplink stuff for outside. unsure about compatibility with existing though. quite happy with it
Jchonline
599
Red Feather Lakes, CO
What you need for that distance is a point to point setup...which would require 2 antennas (one on each end), an access point at the remote station, and a way to power it (I recommend AGM battery, solar panel, charge controller, inverter). EEROS doesnt offer point to point within its lineup, but you can still use Unifi antennas to create that bridge.
Just remember P2P is not a wifi connection...it is a wireless connection between those 2 antennas. Basically as if you were running ethernet from your house up to the gate.
aaluck
Oct 9, 2019
984
836
Snowdoun, AL
Interesting. Yes I do have power. Can you post a link to the device you are speaking of, please.
armylifer
Mar 26, 2013
2,242
1,002
Thurston County, WA
Here is a link to several from Amazon. One thing to think about when you use these is both ends of the power line must be on the same electric circuit breaker box. If the the electrical connection at your gate is on a different circuit breaker box than the one in your house, most of these will not carry the Ethernet signal through two different circuit breaker boxes.
I use these to get a Ethernet connection to my garage and they work very well because my garage is on the same circuit breaker box as the house.
6,016
something like this...https://www.amazon.com/Powerline-Ethernet-Adapter-Extender-TP-Link/dp/B084CZMYNM/ref=sr_1_3?crid=2XMXIIU7EA7WG&keywords=powerline+adaptor&qid=1679344092&sprefix=powerline+adaptor%2Caps%2C91&sr=8-3
I have several TP Link power adaptors (but a bit older now) that have worked very well. You plug an ethernet cable into them and then into your device (if it has ethernet option). You could also plug an EERO into it to extend your mesh network.
They say that your home wiring needs to be in a single panel for the circuit that you want to use. I'm not sure if that is still the case anymore.
edit: I see Armylifer already mentioned it...
9,559
I use a TP OMADA, to cover 1/4 mile at our place.
It works great for mowing and Pandora for tunes.
Jchonline
599
ALot of the power line adapters need to be on the same CIRCUIT as the Access Point (usually a router) just be sure you consider this setup.
If you have power to the gate, PtP is the way to go for the most reliable service.
I would try and power line adapter first, see if you can get it to work. If not return and go PtP.
9,559
Do you get a lot of lightning in your area?
If you do I would avoid the power line option!
5,860
go hardwire : rent a trencher, toss 1" conduit (aka black poly water pipe ) ,run CAT6 cables through it.
Kinda curious as to why you didn't do this when you ran power feed to the gate ?
6,016
I haven't heard of that requirement before. Mine are on different circuits, same panel. No issues.
YMMV
Mark_BX25D
Bx25D
Jul 19, 2020
1,924
1,406
The issue isn't really being on the same circuit. It's being on the same side of the transformer split.
You may see degraded performance if on different legs, and in some cases it might not work.
5,860
yes, PLC modems require to be on the same leg or phase of the power feed but you can 'bridge' the 2 phases/legs,depending on whose 'chips' or technology you're using. This 'PLC' means Power Line Communications and NOT Programmable Logic Controller.
Alfred_2345
L3901, LA525, BH77, SGC1060, RZ60, Box Blade, Z726XKW ZTM, RTV-X900
Jan 5, 2023
134
65
Northwest Arkansas
go hardwire
At 500 to 600 ft, it's too far for a single run of Ethernet, you would need to put in a repeater mid span.
Ethernet spec is for 100m (330ft), you can usually exceed that but I doubt you can double it.
There are "extenders" what can go father but they are not "Ethernet" and you need a converter box @ each end.
Or you can go fiber, multimode will handle 100Mb to 2km, singlemode way faster/further
