KX91-2 hydraulic oil change
twiggly49
B 6000 KX 91-2 B8200
Jan 3, 2022
murrysville pa
I need to change the hydraulic fluid in my KX91-2 excavator.What is the most efficient way to get as much as possible out of the system? Thanks
5,152
Look in the Factory Workshop Manual and find the location of all the drain plugs. Remove them all and leave them out for 24 hours till the last drop of used oil has dropped into the collection pan.
2,833
When I change oil in my cars/trucks/tractors - I try to point them downhill towards the drain plug - if nothing else it does help getting the last little bit out. YOU will never get it all out , but at least you'll get 95% of it out.
cthomas
LX2610 HSDC
Jan 1, 2017
846
561
La Farge Wi
Also have all cylinders retracted(if safe to do so) as this will put more fluid in the tank. And have the fluid warm by running it before draining as this will get the contaminates suspended in the fluid. If possible let drain overnight.
twiggly49
Jan 3, 2022
murrysville pa
Thanks!
twiggly49
Jan 3, 2022
murrysville pa
Thanks!
