B7100 Squeaking
KubotaBoy56
Kubota B7100 with B219 loader and B670 Backhoe
Jan 16, 2022
Washington State
When I drive my B7100 it squeaks what could it be? I doesn’t seem like the fan belt but I could be wrong it only squeaks while driving not on startup
Donystoy
Dec 10, 2013
741
384
Binbrook, Ontario
Last time my B7200 squeaked it was the rear universal on the driveshaft for the front axle (4WD). If it in 4WD, turn it off and see if the noise changes.
11,296
What if the noise doesn’t change then what could it be?
Your really asking a lot of us! 🤨
A noise, a squeak, is really hard for us to hear over a typed forum! :unsure:
Get a video with good audio of it happening, load it up on YouTube and give us a link to actually hear the noise your trying to get us to figure out. ;)
11,296
Even if you do disengage the 4wd it's still goin to turn the Universal joint.
The disconnect is in the transmission so the driveshaft connected to the front keeps turning the joint.
hodge
Nov 19, 2010
2,963
531
Love, VA
It could also be the rear axle hubs squeaking on the shafts, or it could be loose lug nuts. As Wolf said, a squeak is impossible to determine without being in the presence of the tractor. You need a mechanically inclined friend who can walk beside the tractor as you drive it, to help pinpoint where its coming from.
Donystoy
Dec 10, 2013
741
384
Binbrook, Ontario
That is correct. In my case the noise made by the removal of the load on the universal joint greatly changed the sound.
SDT
Apr 15, 2018
3,707
1,429
Bingo.
Insufficient information for any reply other that WAG.
Vigo
B6100, B8200
Jan 9, 2022
595
342
San Antonio Texas
Since you have a loader and a backhoe you're in luck because your tractor is VERY easy to put on jackstands! You should inpsect the u joints on the front driveshaft, at the least.
With all 4 wheels in the air, if you apply the parking brake and leave the tractor in 4wd (engine off!) you should be able to see any play in those joints just by rotating a front wheel back and forth rapidly by hand. If you go slow it will just start spinning the other front wheel in the opposite direction, but if you rapidly move it back and forth you will start banging all the 'lash' in the drivetrain and you will see the wiggle in the ujoints. You have to put some kind of force across it either by hand or this way, because sitting at rest they almost all 'look' fine. You will have to remove a cover to see the u joint at the axle but i believe the one at the transmission is clearly visible from underneath the tractor.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,979
Near Lancaster, PA, USA
A
As others mentioned, it's tough to diagnose noises via descriptions. However, here's an old thread where the poster's printed words worked. Not saying it's related to your problem, but have always remembered it as a success story:
