New to the site so I hope I’m not posting something that has been talked about and I just missed it.
I just bought my first Kubota, a B7200, a couple weeks ago. When testing it out at the previous owner’s house where was nothing that I could find wrong with it. The FEL seemed a little slower than I would of though it should have been but everything else seemed to be working perfectly and it was recently serviced by a Kubota dealer. I have used is off and on since then and it has worked great till today. I was coming down off my hill and was crossing a ditch. As the front end went down into the ditch I raised the FEL up high enough to so that I wouldn’t get caught up on anything. As I cleared the other side of the ditch I pushed up on the level to lower the FEL and it continued up. I stopped the tractor and no matter whether I moved the level up or down the FEL would raise and not lower. It would even rise when I would put the level in the float position, in fact, when placing it in the float position it would raise faster than normal. I then tried to curl and un-curl the bucket. It would only curl (or un-curl, I can’t remember) no matter what way I moved the lever. I then started to wiggle it around and all of a sudden the hydraulic controls started working correctly. A little latter it happened again, same symptoms again and same fix. Then again later on….same problem.
I’m not a hydraulics’ person and I don’t really know where to start or what I want to look for. Any help would be appreciated. I hope that it all makes sense. I will provide more information if I come across it. Thanks in advance!
-Charlie
-Charlie
