PTO Shaft Lube?
The_Wingnut
Grand L4060, ZD21, ZD28, ZD331, RTV X1100C, Branson 3820, JD 1020, JD 50
Dec 8, 2021
91
Tyner, NC
What's the best lube for the PTO shaft? I'll soon be cleaning and prepping, for winter storage, of a lot of my PTO driven equipment and thought I'd see what everyone was using to lube their PTO shafts. I've always just used all purpose grease but it becomes hard and will make it difficult to extend the shaft once it is collapsed past the normal use length.
Suggestions?
Biker1mike
Jan 11, 2022
1,174
1,274
Gallatin, NY USA
I recently started using never seize on the shaft and splines. Expensive compared to grease but it seems to work better and collects less dirt and crud.
Flintknapper
L2350DT
May 3, 2022
1,998
2,532
Deep East Texas
Agreed. Anti-Seize is your friend.
Just don't get any on you. A little goes a long ways it seems.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,440
1,733
Kalamazoo, MI
I just use gun grease then clean and re-apply before next season.
Never seez et al will harden up as well.
ferguson
L3130
Jan 19, 2022
321
125
w.v.
Anti-Seize Had a frend tex me only a week so ago was sealing his driveway. Texed dam driveway sealer just like anti-seizes got s>>t everwhere. Laughed so hard brought tears to my eyes.
johnjk
Apr 13, 2017
1,696
1,896
West Mansfield, OH
I use a spray lube that I can get on the splines and up in the collar to keep it moving and the balls from rusting in place. The brush hog lives outside and I’ve never had an issue with it being seized up when I go to use it. Keep it up off the ground and don’t cover it with something that would hold snow, rain or allow condensation to collect around it. I also make sure I grease up the universal joints as well so they winter without issues. If I was going to cover it, I would use a tarp over the top or an oil soaked canvas that allows airflow but keeps that rain snow and ice off
Bmyers
May 27, 2019
3,498
4,433
Southern Illinois
I use WD-Dry Lube. Been using it for the last three years, no rust on the PTO Shaft, dries clean, so it doesn't collect dirt, and keeps the shaft moving easily.
GBJeffOH
L4060, EA Grapple, 6' LP Brush Hog, 8' snow plow, 6' LP tiller, EA Forks, Spraye
Nov 17, 2014
281
99
Jefferson, Ohio
Suggestions?
I like fluid film. I use it on locks, hinges, rust, etc.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,128
3,388
Anything not sliding or oscillating gets CRC Dry Moly here. Lever and pedal joints, hinges, etc. Even the backside of aluminum wheels so they don't stick to the rotors.
Mark_BX25D
Bx25D
Jul 19, 2020
1,917
1,400
I looked at the Fluid Film website...impressive stuff. Not overly priced, my local ACE hardware even has some in stock.
Yeah, even Lowe's carries it. You can buy it by the gallon, too, for undercoating cars.
I used to hang out on a Jeep forum, and there was a guy who took a one inch square of his underbody and cleaned it down to bare metal. No undercoating, no paint. Just bare steel exposed to the salt and spray of upstate New York. Every fall he sprays it with Fluid Film. He'd been doing it for years. No rust.
It's not a penetrating oil, but it will creep into crevices. Great for slowing down existing rust.
JasonW
569
336
Al
Grease here. Keep them tied up off the ground and I do not leave them collapsed. I leave them out about 6-8in in the chance it sticks I can push them in to break it loose, easier than trying to pull on them. Haven’t had it happen yet though.
Also mine stay out in the weather and still have the plastic guards on them. If possible remove the PTO shaft and store it inside. I remove one half from my tiller and the whole shaft from my post hole digger.
