Help me please
Mike b.
362 72 inch moer diesal
Aug 25, 2022
Huntsville tx.
I have a 326D 72inch disal mower changed water pump flushed raidiator every thing still runs hot help me please
PaulR
Aug 3, 2020
581
460
Hadley, MA
air bound?
My Jeep used to run hot if I didn't have the right mix.
lmichael
Kubota G2160
Apr 23, 2021
529
210
Rockford IL area
So a question or 3. First and most important is why did you do all this work? "just because" and then the trouble? Or the trouble so rather than troubleshoot, throw stuff at it?
JimmyJazz
1,098
644
Pittsburgh, Pa
Maybe your radiators cooling fins have debris stuck in them. Try to power wash the radiator. Get an inexpensive thermal temperature measuring device and make sure the engine is indeed running hot. You have not explained very well your circumstance. Good luck.
Mike b.
Aug 25, 2022
Huntsville tx.
I put it in the shop had them change the water pump new fan belt flush radiator totem it was running hot and it's still running hot
Fordtech86
L3200
Aug 7, 2018
4,818
5,657
Pineville,LA
You took it in because it was running hot and it doesn't matter what they did, they didn't fix anything.
The way I read it, he took it in and told them to replace parts, not diagnose the overheat issue.
I deal with this all the time, customers bring in vehicles and tell us to put on parts that they/their brother/neighbor/ old joe around the corner diagnosed. And that’s what we do, put the parts on and ship it, I’m not responsible for it fixing the issue 🤷‍♂️. They are warned up front as well.
Not trying to be an ass to you or the OP, just giving a different perspective from the other side.
wgator
L4701HST, FEL and other stuff.
Jul 28, 2018
482
147
NC
With radiator cap off and engine running do you see the water/anti freeze circulating?
