Repair bent roller bar on LA535 loader
Tmando
LX2610 HST
Aug 17, 2021
South Carolina
Lock handle was disengaged by heavy brush and right side of bucket came loose during operation.
Bent the roller bar. Is there a way to straighten the bar without damaging the lift cylinders?
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
868
canada
retract fully, then drive up against a solid object to push the bent side back in. If needed you may need to keep the other side out a bit before you push against the bent one to compensate for spring back of the cross tube.
Pony Doc
SSV75 Kioti LK3054 Oliver 1250
Dec 15, 2020
35
20
Central Colorado
That's a fair amount of bend. Consider checking carefully for fractures before and after correcting the bend.
BigG
Sep 14, 2018
1,951
773
West Central,FL
Pull up to a tree then use the hydraulics to push the one side against the tree. This will give you much better control then trying to push with the tractor itself.
Pau7220
Aug 1, 2017
785
279
Scranton, PA
Dump the loader, stick a block of wood between the right ssqa mount and the loader arm, use the loader hydraulics to curl it back in place. You’ll probably have to overthrow it a bit to make it even when resting. Unlikely you’ll find any cracks other than paint, it’s all mild steel. It’s only job is to sync the mounts.
Chanceywd
Mar 26, 2021
690
612
central ny
Because I have seen others have this problem I came up with this before i used my grapple. It may need something different with other styles but for mine it just flips over to lock or unlock. I also added some perforated steel to the large opening in my grapple. The hole for the lock is drilled thru the handle and tapped for a 5/16 bolt. I then tighten the bolt so there is a little tension on the lock but moves easily and then i tighten a lock nut to keep it there. The other bolt is just a handle. I find in using it to flip it over as far as possible when open ( actually farther that the picture shows) to keep from hitting on the attachment I am changing. So far it has worked well for me
Bill
5,697
Have seen that here, all to often, it's a really ,really bad design. While you can 'tweak' it back to normal, the steel is 'stressed',so weaker, meaning it'll bend again,under less stress. Adding a second bar(pipe) near the lower edge would strengthen the frame,lessen the chance of bending,adding maybe 20#s .
Curious if this is just a Kubota problem with SSQA frames or do other mfrs fail as well ??
Chanceywd
Mar 26, 2021
690
612
central ny
I agree Jay. It would seem like some kind of small I-beam shape or box tubing maybe 4" or so would resist twist better than a piece of round stock only about 1-1/4" that is the oem design.
Bill
6,639
Pau7220, I can load a picture as fast as you type !!! Same subject, same idea, same time. ;)
6,639
The cure is to confirm the locking pin is totally engaged at the beveled end. That is it's down in the opening in the lower plate. Take time to check when one lowers the latching lever and it won't happen.
nbryan
Jan 3, 2019
1,305
827
Hadashville, Manitoba, Canada
I can assure you that is the unintentional release of one of the ssqa latches it CAN happen, even though the latching levers have been properly engaged with the pins fully locked into the lower plate.
In my case the cause was a wayward brush branch on the forest floor. While backing up and looking backwards, with the forks mostly lowered a stick poked up between the tractor and ssqa and popped open the right lever unbeknown to me. My motion brought the bottom right of forks against a solid stump and slowed the tractor which I of course compensated for with a little more hst pedal which didn't work - of course bending away the right forksaway from the ssqa frame about 1 1/2" on that side.
My "design correction" has kept the levers locked for 3 years now with ongoing and sometimes approaching severe bush abuse. I don't worry about shit popping up and screwing up my ssqa while I'm not looking, any more.
Donystoy
Dec 10, 2013
667
302
Binbrook, Ontario
Looks like I will have another "mod" to do to my new tractor so I do not have the same issue.
2,073
@nbryan
Clever idea and nicely designed
I assume you did not want the leg of the angle iron below that bar for easier unlatching (only have to remove one pin)?
Pau7220
Aug 1, 2017
785
279
Scranton, PA
Yepper… I didn’t know there was a youtube video for it. We must have hit submit at the same time.(y)
Pawnee
L2501
Jul 1, 2021
356
321
Ontario Canada
nbryan
Jan 3, 2019
1,305
827
That modification is a beautiful thing!
Stared long enough at my various parts ("junk") piles/bins, and given a drill, metal cutoff blade on my circular saw, and grinder, made it work. I am good at visualising shapes, systems, and solutions and sketching quick plans if a sketch needed. My career as construction contractor made use of those skills all the time.
I'm quite happy the lock bar has not needed any tightening or adjustment at all, either!
nbryan
Jan 3, 2019
1,305
827
@nbryan
I only have to remove/install that one lock-pin I added. It's all that's needed to keep the angle down. The angle pivots up and away once the pin is removed.
