How does the hydraulic shuttle and clutch work in an M6060 or similar.
9,206
I'm not asking about the simple explanation of how it works or it's purpose but rather how it works mechanically. I'm very familiar with manual transmissions, clutch disks, pressure plates, throw out bearings, clutch linkages etc., but have no idea about the hydraulic shuttle, wet clutch disks, or the clutch on the M6060 and how they all work together.
I've started looking at schematics online at Kubota's illustrated parts list but it's hard to get an idea of how the clutch works and how the shuttle works.
Thanks very much.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,434
1,728
Kalamazoo, MI
The best explanation I could provide is the foot clutch works just like any other foot clutch. It disconnects the transmission from the engine (excluding PTO). The hydraulic shuttle clutch pack is downstream from the foot clutch and includes a set of reversing gears.
9,153
Trying to explain the process I'd probably just butcher it up.
I'll send you the WSM and look on pages:
Adobe pages 246-251
or
Manual pages 2-M3 - 2-M11
This should give you a good idea what's going on.
9,206
Adobe pages 246-251
or
Thanks very much. I downloaded the manual and am reading the section on the Transmission. Once I've got a basic understanding I'll try to ask an intelligent question or two.
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,010
1,388
Pittsburgh
Adobe pages 246-251
or
Send to me as well, plz.
3,389
1,978
Thanks very much.
Assuming it works like the hydraulic M6040, there is no conventional clutch. There are 2 hydraulic clutch packs (plus a third one for the PTO), one for forward and one for reverse. The shuttle lever controls a selector valve that directs oil to one or the other.
The clutch pedal controls a pressure regulator that controls how much pressure is applied to the clutch pack through that selector valve. When fully depressed, no pressure - when foot off the clutch, full pressure.
That's the basics, there are a few details you'll see on the clutch hydraulic flow diagram.
9,206
Thanks very much.
The reason I ask is that I've noticed something a little odd with the M6060. When I start the engine and let it warm up for a few minutes, the tractor starts to "rock" back and forth about 1 to 2 inches. It will do this under the following conditions.
Hydraulic shuttle > N
Transmission gear selector > N
Parking brake > Off
Clutch > Not depressed
Range > Low
2WD/4WD > 2WD
If I start the tractor with the transmission gear selector in 3 but everything else the same it won't rock back and forth after a couple of minutes of warming up.
I'm trying to understand how the tractor can move at all if both the hydraulic shuttle and transmission are in N.
I spent some time looking for other cases like this and found at least one example on this forum dating back to 2018.
9,153
Thanks very much.
Parking brake > Off
Range > Low
2WD/4WD > 2WD
First thing I would do is a complete fluid and filter change, as I've seen a lot of issues with clutches and valves due to wrong / bad fluid.
9,206
I bought the tractor new with 1.1 hours on it and it has about 4 hours now. It's possible that the dealer put the wrong hydraulic fluid in but it's unlikely. It takes 15 gallons so I sure hope that I don't need to replace it. The M is going to the dealer to have some upgrades installed so I'll have them look at it then.
9,153
Sounds like a good course of action for now!
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,254
161
Coyote Flats,Texas
Your info about traction clutch is incorrect.
These type tractors with hyd shuttle have a damper clutch that never gets disengaged. The foot pedal is connected to a hyd valve which when depressed limits hyd pressure to hyd shuttle fwd or rev clutches
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,254
161
Coyote Flats,Texas
mcmxi
I've read of other Kubota tractors rocking back & forth in neutral when 1st started after being not operating(cool) a period of time. I think it's just the "nature of the beast" .
When I 1st purchased my '11 M7040 with 137 hrs on speed hour meter every once in a while on initial engine start up I could hear a rumbling sound under instrument panel. After several 100+ hrs of use the noise went away. Tractor now has 1600+ of trouble free use
9,206
mcmxi
Thanks for the feedback. Even if it's the "nature of the beast" I'd still like to know how it's possible given that the shuttle and transmission are in N. As I mentioned, if I have the transmission in L3 when I start the tractor it doesn't appear to do it but it will in L1.
I'm still reading through the WSM that @North Idaho Wolfman provided but slowly getting a better understanding of the drivetrain. I want to be as informed as I can be when I drop the M off to the dealer for upgrades including creep, 540E, third function, 3rd rear remote, ballast, top-n-tilt and widening the track width. Maybe it won't do it once the creep option is added ... who knows!
