B8200 hydraulic fill location
bigmarkor
BX8200
Nov 28, 2019
10
Yelm, WA
I have a B8200 that I need to change out the hydraulic fluid on but for the life of me I can’t find where the fluid fill is. I’m post a couple of pics of where it’s supposed to be if an anyone can help it would be much appreciated. Where the owners and service manual show it being it is not at.
Thank you
11,280
Slide the seat back on the rails.
Right side under the seat.
3,091
This is where the "book" shows
You could fill via the dipstick hole - but that would take a lot of patience.
11,280
WOW, someone has put a different cover on the shifter (It was an optional cover that did not have the fill port on it).
The other fill port has been used up by a return line, it's in the third pic you put up (under the seat).
Is there a loader on this tractor?
I'm wondering if there is a fill up there as there were a few of these that has a added hydraulic tank on the loader frame.
bigmarkor
BX8200
Nov 28, 2019
10
Yelm, WA
It does have a front end loader on it but I don’t see anywhere in the frame of that where there would be another tank. Thank you for the info by the way I appreciate the help. I take it I could just disconnect that return line to refill the hydraulic fluid and then reconnect it after?
3,091
yes - that is about the best answer:)
11,280
Other option is a small funnel though the dipstick port.
11,280
Thank you for the help! I wound up putting new seals in the hydraulic pump, changing out the hydraulic filter and then filling her up with new UDT2. Works like a dream now!
Excellent
