B7100 rear wheel hubs
5,248
8,745
The gray one's hands down.
They won't loosen and they hold better.
arml
B5100e BX2200 JD455AWS G1800
Jan 27, 2022
222
236
Pennsylvania
First measure your old hub, I think you will find the orange one will be
too small. Also the orange one is a real pita because of the bolt setup.
Gray one is really good, has studs measures 7 1/4" across. bolt center across the hub will be 6", stud center to to next stud will be 3" also as
Wolfman mentioned, easy to adjust and, holds tight. On my old hub I tack welded the bolts in reverse of the original setup so it out the front like studs....sure makes it easy to remove and, install the wheels.
Lencho
B7100hst
Jan 21, 2017
428
101
NM
I swapped my stock one for the grey version several years ago and they work great.
5,248
I must be losing gray cells faster than I feared and I stand corrected. I just went and looked and I actually used the gray not orange type when I replaced the worn out OEM hubs on my tractor. That was many years ago and unlike the OEM (orange) style they have been totally trouble free..
b4200
9
ohio
Another vote for the gray ones. My original hubs are like the orange ones and no matter how tight you get them, they will loosen back up at some point and wobble.
I picked up some gray ones from the Bay of E and have had no issues with them.
Dieseldonato
Mar 15, 2022
728
439
Pa
Grey ones on my tractor as well. Heck of a lot tighter then the bolt style. Easier to remove imo as well
torch
Jun 10, 2016
2,742
960
Muskoka, Ont.
If you are a cheap dutchman like me, you can take a grinder to the originals, open up the slit a bit and then they'll clamp down again nicely.
