Three point hitch bushogs
1badDart
109
108
W. KY.
I've only been on this site for a couple months but grew up on a farm and have operated tractors all of my life. I've noticed in several photos of tractors and 3ph bush hogs with standard threaded top links. Has anyone ever used a chain in place of the top link? We always ran a chain (I still do), even if we were clipping pastures.
What happens with a top link is if you get on a stump or something large is that the bush hog can make the tractor buck, possibly tossing the operator off the tractor and running over them. A chain will allow the bush hog to jump up and prevent it from causing the tractor buck.
Over the years I know of three guys who have been killed this way.
Stay safe guys.
6,728
Have run a chain in the past. Have also put the top link on for transport and off to mow. Currently run a hydraulic top link with float and float it when actually mowing. I have really liked the hydraulic top link with float.
Elliott in GA
Mar 10, 2021
881
892
North Georgia
Three things: (1) you should be wearing your safety belt - you cannot be bucked off, (2) my Quick Hitch hooks under the pivot link on the rotary cutter - it can pivot up and down to absorb/ride over any collisions and (3) with an HST, if my foot leaves the pedal the tractor stops immediately.
nbryan
Jan 3, 2019
1,427
947
Hadashville, Manitoba, Canada
It seems my M5 mower can if forced to "jump up" quite a ways already given the freeplay of the lower arms when they're lowered to mow, as there's no 3-point downforce and the mower would have to jump 2-3 feet up before the lower ams would "top out". Is that how these mowers kick up the tractor's rear? Fly up past the 3-point free play? If so I may strongly consider opting for the chain on the mower top link instead of the factory threaded bar.
That just seems like a lot of force beyond bouncing on a solid stump would impart, then again I'm only running barely the minimum pto hp with my B2650, maybe stronger pto tractors would suffer this phenomenon more easily?
And if you have a ROPS, wear the belt. Tossing hazard gone.
1badDart
109
108
W. KY.
(1) None of the older tractors have seat belts, at least none I've owned or operated. (2) A lot of people still don't run a quick hitch. (3) Most tractors aren't HST.
Stay safe.
SDT
Apr 15, 2018
3,685
1,408
Stay safe guys.
I have used both rigid top links and chains on multiple tractor/rotary cutter set ups over the decades.
Used chains with some tractors/mowers to prevent damage to internal draft control mechanism in certain circumstances.
SDT
Elliott in GA
Mar 10, 2021
881
892
North Georgia
Stay safe.
While true about older tractors, most (the vast majority) of the photos I have seen on this site are of more recent vintage tractors with ROPS, seat belts, HST and maybe a Quick Hitch.
I did not realize that you were talking only about antiques. :LOL:
If I had an older tractor, I would add a ROPS and seat belt if at all possible. There is even help to reduce the cost .
I do not know how well the program works, but it probably helps.
1badDart
109
108
W. KY.
A seat belt is only good if you wear it, I hope everyone does.
Elliott in GA
Mar 10, 2021
881
892
North Georgia
FWIW, Messick's has a video about rotary cutter travel with respect to top links.
It offers a cheap solution at the 8 minute mark.
Better or worse than a chain? I do not know.
DDCD
1964 MF135, L2501
May 8, 2021
160
179
Oklahoma
I have a bush hog with a chain from the 3 point mount to the back of the mower. Rigid top link from mount to the tractor. I have to have a way to pick up the mower.
Mowed in plenty of dips and ditches and no bucking me off. Maybe I'm doing it wrong, but the mower link and chain seem to move freely. This is on a 60 year tractor with no seatbelt.
1badDart
109
108
W. KY.
Your chain is doing the same thing as using a chain in place of the top link. I'm not saying that not using a chain is going to get you hurt, but if you mowing in rough places with stumps or other large objects at least consider one.
In the end use what you choose, I choose a chain.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,447
1,743
Kalamazoo, MI
Tell me about the "bucking tractor." I'm not understanding. Is the tractor popping a wheelie when you contact a hidden obstruction?
Tire Biter
B 2601 434 loader MMM, bunch of tractor stuff . Ford 4600
Jul 10, 2012
238
88
S.E. TN
I alway use a chain with an extra clevis part way up the chain and use it to tighten up the chain for transport. There are some situations where a solid link will bind up where I mow. Never thought about the mower catching and flipping the tractor and I doubt it could even happen.
1badDart
109
108
W. KY.
Never heard of one flipping but do know of three guys that have been thrown off and run over. This has been over the course of many years.
NHSleddog
B2650
Dec 19, 2019
2,144
1,839
Southern, NH
I use my top link all the time with the brush hog so I would not go to a chain I like the on-the-fly adjustments.
I drop it over banks and angle it down, I angle it up and back up over nasty stuff etc. On my unit (5ft Mahindra) the top hook frame can "float" about 6".
Fordtech86
L3200
Aug 7, 2018
4,966
5,919
Pineville,LA
Have a rigid top link on tractor and a floating top link on bush hog. But can’t see how the mower hook up itself would cause someone to get thrown over. I have lost the top link pin and got stuck in the ditch because I couldn’t pick the mower up, bout it.
In Utopia
L175 FEL
Apr 21, 2013
667
199
Utopia,Tx/Pasadena,TX
Not only does my Brush Hog brand rotary cutter have a chain on top, but also limiting chains to keep it at a constant height since older tractors won't hold position very well. Most people probably wouldn't cut the areas that I do. Pretty rough terrain, lots of ups and downs.
Magicman
Oct 8, 2019
6,057
9,535
Brookhaven, MS
knotholesawmill.com
Neither my 3008 Bush Hog nor my smaller 6' cutter have a top link at all. It's called a 'semi lift' where the rear cutter wheel(s) are always on the ground the cutting height is adjusted by the tractor's lift arms.
Another view of the 3008 which has 3 wheels. Notice that there is nothing for the top to attach to.
