carbide coated mower blade search
Tractor Gal
BX23D MLB
Oct 30, 2020
585
231
NC
I had seen someone online talking about mower blades for a RCK60B-22BX which were carbide coated and according to him, these blades lasted longer and cut better. Sadly, I can't seem to find the link where I saw these.
I've checked on ebay but most of the blades are not for -22BX but -23BX. I don't know what difference this would be but I don't want to buy something and it doesn't fit.
So, if anyone has a moment and knows, I'd appreciate knowing the specs of blades to order for this mower. I think the brand was Oregon Carbide Gator Fusion but sure can't find it now. Maybe I have the wrong brand, etc.
Thanks for helping.
Tractor Gal
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,589
1,825
Near Lancaster, PA, USA
Something like this? Not sure of the size. I bought some from AgriSupply for one of my Caroni decks.
Tractor Gal
BX23D MLB
Oct 30, 2020
585
231
NC
Looks like a good start, chim. Thank you. I'll check sizes, especially mounting hole diameter.
TG
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
995
1,343
Pittsburgh
I has teh Part #396-612 Oregon G6 on my RCK60.
I has teh satisfactory mowing/mulching experience.
Ze Germans have a word for it: fahrvergmöwing.
Tractor Gal
BX23D MLB
Oct 30, 2020
585
231
NC
Thank you, hagrid. Seems these blades work all over the world! Wish I knew some German to respond. I'll look into this part #.
Tractor Gal
CGMKCM
RVT-1100C, ZD323, L4760
Jan 26, 2021
453
240
Randolph county N.C.
I have used these blades on my ZD 323. In my sandy soil they did not last much longer than the OEM blades and they cost more. Hopefully they will work for you.
Tractor Gal
BX23D MLB
Oct 30, 2020
585
231
NC
Good to know, CGMKCM. I guess in the big picture, it's "how you mow." Or, maybe included in that is "what you mow." :) I've sharpened the blades that came with the mower so we'll see how they do. No point to buy new until I see how things go.
But, I do appreciate the comments from those who responded.
TG
5,465
2,160
I had same experiences with a couple sets of oregon blades. Cost more, don't cut any better, don't last no longer. I use OE kubota blades exclusively now. When I had my Deere, same thing. OE blades cut better and cost a little less. And easier (for me) to get them since there's a deere dealer within a minute of where I work, and secondly not a single place in the 30 minute radius keeps any oregon or gator blades in stock unless they're for Murray's or the like. That's what they're more geared toward anyway, those oregons are a little less expensive than oe crapsman/ayp/murray/mtd/yard man blades.
reminds me. I had to work on my friend's mower a while back. Just poorly maintained, I had to fix a lot of little things that were neglected (like briggs valve adjustment). It was a Wizard brand. Little older but in pretty good shape. Uses 2 different length blades (3 blade deck), 2 outside blades were the same, center blade shorter. Stupid setup. The cheapest set of blades I could find for it were over $85 for the set and they were aftermarket, OE was over $100. I can get a full set of 3 OEM mulching blades for my Kubota for $55 with tax.
Tractor Gal
BX23D MLB
Oct 30, 2020
585
231
NC
Good info, lugbolt. I'm learning more and more every day about this whole BX thing! It's a great little machine...as are many brands. Maintenance is the key, as well as not abusing while using. :) Thanks for the tip.
TG
3,878
2,522
I tried hard facing the cutting edge. Yes the edge lasted a little longer but my sandy soil sand blasts the blades paper thin by the end of the season. I figure it's just cheaper and easier to replace the blades every spring.
I've been alternating with K high lift and cheaper oregon blades, whatever is the best price at the time.
Tractor Gal
BX23D MLB
Oct 30, 2020
585
231
NC
Thanks, mikester. You must be doing a lot of mowing to get new blades every year! I'll just have to monitor and see what develops over the season. Thanks again.
TG
CGMKCM
Jan 26, 2021
453
240
I put about 100hrs per summer mowing. I change blades 2x per year. I have been using these blades, they are much less expensive then the Kubota blades.
Blades
Tractor Gal
BX23D MLB
Oct 30, 2020
585
231
NC
Yesterday at the Kubota dealer, I learned that the cup washers have been designed to keep the blade spinning properly. The bottom one pushes up and causes the top washer to flatten a bit but the bottom one does not flatten very much, holding tension on the blade. Two are required on each blade for the RCK60B-22BX. This mower does not have the cup washers on any of the blades! Plus, one blade was missing the lock washer.
Yes, a little "off topic" for a request for opinions on blades but it all works together. :)
TG
CGMKCM
Jan 26, 2021
453
240
TG
You might want to go to the parts counter at your local Kubota dealer. Someone remove the two cup washers and added lock washers? Lock washers are not needed if the bolt is torqued correctly. This info is from my ZD series WSM. My deck is very similar to your deck.
Adf
B7200HST
Nov 23, 2019
46
Joelton,tn
Thanks for helping.
Tractor Gal
I cant tell you ehere to get them but my BadBoy mower comes with them and they do stay sharp incredibly longer
Tractor Gal
BX23D MLB
Oct 30, 2020
585
231
NC
You might want to go to the parts counter at your local Kubota dealer. Someone remove the two cup washers and added lock washers? Lock washers are not needed if the bolt is torqued correctly. This info is from my ZD series WSM. My deck is very similar to your deck. View attachment 60274 View attachment 60275
I hear what you're saying, CGMKCM, but it's not the "lock washers" we all know and love. It is called a lock washer...notice in the diagram you sent. #7 is called a lock washer. It is the stop sign kind of lock washer. It fits directly onto the bottom of the shaft and is the same shape. No need to go to the parts counter. :)
TG
Tractor Gal
BX23D MLB
Oct 30, 2020
585
231
NC
I hear ya', Adf. When I get new blades, I'll come back to this thread to check things out again. For now, I've just sharpened what is there and will see how it goes. I don't have to do a lot of mowing with this mower so all should be good for now. Thanks for your good report.
TG
CGMKCM
Jan 26, 2021
453
240
TG
TG
I get it now. On the Messicks parts site they refer to that #7 piece as a blade holder.
atitus
BX1880+FEL,MMM,Blower
Feb 11, 2019
144
21
Worcester, MA
I have the 48 in deck. Diagram in the manual also shows cup washers. But in fact they aren't actually there on the machine. I've had it for 3years so far so good without them. I am sure the blades aren't slipping during use because I can see how clean it is on the spindle caps under the blades when I take them off to sharpen :)
