Rtv x900 fuel filter replacement
Beagleman
12
Florence,ms
Operator manual says contact dealer for fuel filter replacement. Is there anything special needed to do this. Could someone tell me how?
3,450
kubota rtv 900 fuel filter change
3,186
1,604
You just unscrew the filter cup, pull the filter out of the cup, clean out the cup, install the new filter into the cup, reinstall the two o-rings, screw the cup back onto the filter housing. The filter head has an automatic fuel shut-off valve built into it so it will not keep running out while you have the filter cup off.
No need to bleed it, start the unit and you're ready to go.
The video that was posted is for an RTV900, not a RTV-X900. They are totally different units.
5,473
2,164
actually you will have to bleed it if you use your method.
to add to your method....when the filter bowl is screwed back on, don't tighten it up quite yet. Screw it on until fuel flows into the bowl. Let it fill the bowl, fuel should be running out around the threads. Once the air bubbles subside, takes typically 5 seconds give or take, tighten it up and you are done--no bleeding necessary.
Works for B series and smaller L series too. And M series and bigger L's, though they have a different fuel filter/bowl assembly....same principle.
Robert walker
Kubota L3400
Jul 16, 2020
East Texas
My question is where is the fuel filter located On the RTV-x900? Is it on the bottom of fuel tank? I bought a filter kit from Kubota dealer and it had a fuel filter but I saw in the manual it said contact dealer. Can’t be that hard.
ZTMAN
BX2380
Aug 26, 2018
166
88
South Central Pa
Take a look at Messicks website. They have a parts look up tab, and you will find a diagram for the fuel system
3,186
1,604
It is just ahead of the Right Rear tire.
