Kubota B7800 Fabricating Side Rail Bell Housing Supports.
Hodgy
B7800, front blade, box blade, subsoiler & 3 PTH snowblower
Apr 19, 2019
126
9
After two broken bell housings and two blown clutches I decided to fabricate side rail supports for my 06' Kubota B7800. I used 6" x ½" steel plate and connected the engine rails to the rear rails to support both the aluminum bell housing and the cab support structure. It was on the last clutch repair that the mechanic at TractorLand in High River Alberta indicated that the tractor lacked support for the bell housing. He noted that loader tractors had a bridging support that joined the engine frame and the rear of the tractor thus giving strength, The front support for the cab also was attached to the aluminum bell housing putting more weight and stress on the joint between engine block and bell housing. My tractor had no such support.
Here is a fairly long youtube video of the process. Hopefully I have fixed the defect.
5,121
What model front hitch is on it?
As the original hitch mount also included a subframe to stop what's happening to you.
Hodgy
Apr 19, 2019
126
9
I don't see a tag on the front hitch but your drawing looks like the same one. Your attachment has the number 56374 on it. Is that the Kubota part number ?
Hodgy
Apr 19, 2019
126
9
I did some digging and the subframe number for my B7800 is B1791A. Looking like the part number is 77700-05037 which replaced 70060-0236. No where in the diagram does it show the side support rails.
Do you know the part number for the rails ?
Hodgy
No code has to be inserted here.
5,121
The subframe is part # 70001-00612
The hitch is whole goods# B2761
