L3600 GST Start Issues
OlMacDonald
L3600 GST
Jun 30, 2017
Newfields NH
Past few months, starts one day, not the next. Replaced old battery, cleaned ALL connections from battery (to include ground) to where wiring off starter enters the firewall. Replaced both micro switches (on fwd - aft shift lever and above parking brake). Cleaned all blades / receivers on all QDs aft of the firewall. Some days key just clicks when start position selected, other times it starts. All PTOs in non engaged position. I unable to discern any logic to failure.... general consensus is to replace the starter relay. Unable to figure out which of the five relays inside the firewall is starter relay. ....damn 'trons. Thx for any help!
8,705
If only there was a place to find this kind of information...;)
Alas the WSM, I'm sending you a link to download a copy. :D
5,450
2,139
Check voltage at the starter's trigger wire with someone trying to crank the engine. Hopefully it'll just click when you check the voltage. If voltage is under about 10v at the small wire, you're going to want to look at the harness or relay. Harness would be my guess. IIRC those old grand L's had 2 or 3 connectors between the front harness and the rear harness, and were known to get a little dirty-causing a voltage drop across the connector. If that's what you find, just clean it and put some dielectric grease in the connector before reconnecting it. Could also be relay, but I don't remember ever having to replace a starter relay on a grand L. Wiring harnesses are a different story.
Oh, just thought of it. Check the ground. That was a poor setup. The ground wire comes off of batt (-) terminal and runs down under the battery box to a frame ground point. Well the battery had a tendency to cause corrosion under there, which gives you a poor ground. To access it, you have to remove the battery and partially remove the radiator support, IIRC, then the tray. Myself, I usually run a new ground down beside the radiator and ground it on one of the unused bolt holes in the frame, just clean it off good.
jbutler
L3600
Apr 1, 2013
If someone has access to the WSM for a L3600 I would appreciate getting a copy.
Thanks in advance.
Dr Rox
L3600 GST, frontend loader, bush hog, box rake, disc tiller, cultivator
Jul 8, 2021
10
NC
Thanks in advance.
Bump!
ME TOO!
Having starter issues - no relay click, no starter energized.
3,398
i had a similar story…and found the solution… finally FIXED! (when you click on the link…. go to the Post #1 to get the full story.)
