L275
L275F, L2850D, BF500 Loader, FS1020, M5-4 Cutter, 500 PostDigger, CRB60 Blade...
I installed a temperature gauge on my L2850D in the top radiator hose with an inline adapter. It worked out well and was simple to install.
Ran the Temp gauge cable through the fuel tank tachometer cable channel behind the instrument cluster panel. I used the top radiator hose for the best temp reading with a Stewart Warner gauge mounted to the side plate by key switch with a rubber grommet through the plate for the sensor cable.
Parts included in pictures with part numbers. Gauge could be replaced with much cheaper one (Just my personal preference).
