Loader & manual wanted for l3400
poolnut
l3400 kubota, bobcat 430, bobcat t190, bobcat s570
Jan 13, 2021
iowa
Looking for loader and service manual for l3400
I think a LA524 or LA463 will work ? If you took one off let me know model and I can see if it will work. Thank's
3,654
Don’t know specifically about the L4300... but lots of different loaders can be fitted onto different tractors. There’s at least FOUR different ones and TWO different “Genuine Kubota” loaders can be on my model tractor.
So.... you might want to specify WHICH specific loader you are asking about.
9,282
WSM (aka service manual) and OPs manual are both available on kubotabooks.com
poolnut
Jan 13, 2021
iowa
I was going to ask local dealer are you? Can you tell me models and I will add to post. Thank's
old and tired
L2800 HST; 2005; R4
...Can you tell me models...
LA463 (original FEL) and LA524 (updated series for the "Standard" L Models). They both lift the same weight, but the location of where that weight was measured from changed.
For L3400, the L2800 used the same same loader. Not sure exactly when the LA524 came out, if it was mounted on some L3400 or L2800.
LA463 used a "C" channel to hold up the loader where LA524 uses a single arm (#2)
Any of the "Standard" L's after L2800 and L3400 uses the newer LA524...
