Spool Valve
flynavy
B7100 HST-D w/FEL,654 Whel Hrs w/blade, 2654 Hsqv mowr, 28h Cfstm snowblower&cab
May 1, 2014
95
Laurel Springs, NJ
I recently replace my 2 spool control valve with a 3 spool. Only so I had another valve for future use. The old 2 spool was twice the size of the new 3 spool. My question, the new spool valve gets very hot to the point it'll almost burn your hand when touching the body of the valve. Is this normal or did i mess up.
Everything works as it should, but the 3 third position is plugged off and not used yet.
Any help most appreciated
5,257
1,053
It sound like something is not correct. A hose in the wrong place perhaps.
Fluid is being forced through a relief valve generating heat.
Does your new valve have power beyond?
Is your loader connected into the tractor's hydraulics or does it have its own pump driven off the front of the engine crankshaft?
Please provide details on the new valve..... make, model, spec's, etc
flynavy
May 1, 2014
95
Laurel Springs, NJ
The new valve controls the same operations as the old valve, bucket tilt. up/down, and arm lift, up/down. It does not have power beyond. And yes it's on the tractor hydraulics.
old and tired
1,919
1,297
Heating up is bad for hydraulic oil (shorten life span)... since there's not much to go on with the spool's make or model numbers and no photos to see how it's hooked up... Don't know what else to say...
10,277
You say it doesn't have power beyond?
It must as the three point runs off of the PB line.
How may hoses (besides the 4 for the cylinders), 2 or three?
If 3 then it has all the right lines.
If 2 then it does not have a tank line.
Also sounds like it has a pressure relief valve that is not set right and without a tank line it will get super hot as it's running the pump against an valve that has no relief.
More info will help to narrow it down.
flynavy
May 1, 2014
95
Laurel Springs, NJ
I took off the old 2 spool and replaced it with a 3 spool. Installed right out of box no adjustments
2 hoses one for Line in, one Line out, and 4 hoses, two hoses for the lift up, and down, and 2 hoses to the tilt up and down. the 3rd spool ports are just plugged for now its for future use to control an accessory.
Photos below.. Te block w/2 hoses (picture #2) goes to the in and out of the new spool valve
Thanks for telling me that the power beyond is for the 3 pt. I really didn't know that.
flynavy
May 1, 2014
95
Laurel Springs, NJ
If i Need to adjust the pressure, please enlighten as I don't know how to achieve this and what equipment would I need to buy to do this.
Thanks soo much for all your help.
flynavy
May 1, 2014
95
Laurel Springs, NJ
View attachment 53116 View attachment 53117
NHSleddog
B2650
Dec 19, 2019
2,144
1,839
Southern, NH
I did the opposite, I went from a small single spool (OEM supplied) valve to a larger (15GPM) 3 spool valve.
Mine gets HOT. Basically the temp of the hydro fluid in the tractor.
10,277
You would need a pressure gauge and you could tap into the third spool to test it.
The pressure is adjusted on the front left side in picture.
But it will not go higher than the total system pressure, but you can change that to to some degree.
flynavy
May 1, 2014
95
Laurel Springs, NJ
What's the acceptable psi for the low.. and high end of pressures ?
I looked at gauge sets on both ebay and amazon, could I impose on you to suggest which one would work for I need to achieve? They are many different ones and I don't want to get the wrong one. Thks
flynavy
May 1, 2014
95
Laurel Springs, NJ
10,277
I can't thank you enough!
I'll order that gauge immediately, will this gauge need any adaptors? say 1/4" to 1/2" Because I believe the valve body uses 1/2" plugs
Yes you can pick up brass 1/4" to 1/2" adapters at HD, Lowes or other hardware stores.
flynavy
May 1, 2014
95
Laurel Springs, NJ
Thank You O Sooo Much North Idaho Wolfman!!!!
Ok, so here's where we are...
Finally got the adaptor for 1/2 to 1/4, for the gauge, placed the gauge on spool #3 ( far right side), the gauge was reading at 2300 psi then I adjusted down to 1700 psi when in use. At running speed with no hydraulics being used it reads between 700 & 850 psi. Is that idle reading OK?
flynavy
May 1, 2014
95
Laurel Springs, NJ
Finally got the gauge and adaptor for 1/2 to 1/4, for the gauge, placed the gauge on spool #3 ( far right side), the gauge was reading at 2300 psi then I adjusted down to 1700 psi with spool operated. At running speed with no hydraulics being used it reads between 700 & 850 psi.
Also at idle when I operate the "down" operation of another spool valve the gauge reads around 500psi, is this ok?
The overall spools seem to operate the bucket slightly slower but smooth.
