The MX5800 manual states 9.9 quarts for oil capacity with oil fillet change is 2 quarts overfilled
n4khq
M6040, M7040, L39 Backhoe, M8560, MX5800HST, MX6000
Nov 10, 2018
40
Dahlonega, GA
I checked an recheck the manual before changing the oil in my MX5800 for the first oil change at 50 hours. I checked the oil prior to the change and it was at the top level. After draining and adding 9.5 quarts I poured the old oil back in the containers and realized I had a little less than 2 gallons. The oil was an inch and a half above the top line. I tried 2 hours to get a hose into the oil pan but nothing worked. Finally I removed the plug and drained out 1 3/4 quarts. The oil was 1/4 above full. I stated and it was 1/8 inch above full after filling the filter. I removed and emptied the filter. I started the tractor again and the oil is 1/16 of an inch below the mark. I fear it will be high when the oil drains down. If it above the high mark do I need to take out more oil?
I found two more users on the web with the same problem. I use the hate greasing equipment more the oil changes but after todays experience with incorrect manual, a grease job would be easier.
SidecarFlip
Banned
561
The capacity in your manual is the DRY FILL capacity. There will always be a bit in the engine that won't drain no matter what you do.
When I change mine in my M's I always add 3 quarts less, start the engine and the fill to the full line on the dipstick cars likewise. My cars call for 5 quarts. I put in a gallon and top off accordingly.
n4khq
Nov 10, 2018
40
Dahlonega, GA
Thanks for the reply but 2 quarts seems like a lot of oil not to drain out with a warm engine. The day before I changed the oil on my L39 backhoe. It called for 6 quarts. I added 6 quarts, ran the engine and let it set over night and the oil was only 3/4 the up from the low mark. I will certainly follow your suggestion for future oil changes.
JohnDB
M4500DT with FEL, back blade, Someca K28 hay mower, drag broom, post driver
Jun 9, 2018
458
97
NZ
the book is wrong
Seems to be a problem more common than I would have thought - M4500 WSM has bad quantities - front diff case 70% overfull, axle cases 30% underfull, bevel gear cases 25% underfull, I always go by the level indicator.
2,344
It is probably the conversion factor from liters to quarts was incorrect or used incorrectly when the book was translated.
To the original poster: please post the value in the book for the metric value if it is included.
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
I know nothing about your particular tractor but just a thought...does it have two drain plugs and were both of them pulled to drain the pan?
parts diagram shows it has two plugs.
