Back Blade for snow removal with horse mat
sam24and48
BX2200
Feb 19, 2018
30
11
Goshen, IN
This will be our second winter at our current house with a pretty long drive made of asphalt millings. Last year I added skid shoes to the blade to keep it up off the drive. However when setting the rear blade at an angle the skid shoes take that same angle as well and dug in substantially into the driveway. I also used a small snowblower on our concrete pad as to not scrape up the concrete with the rear blade and shoes. This year I added a horse mat strip from TSC as many have used to keep from scraping up the pad. I am curious if anyone has suggestions on possibly a wheel set up similar to what is used on landscape rakes to keep it just above the grade. I am not great at fabrication, welding, etc. so something that could be attached at the bolts for the blade would be great. I may just have to float it manually as I go, which isn't the end of the world, but I wanted to see if anyone else had some other ideas.
Hopefully that all makes sense. I attached some pictures of the driveway and blade. Our turn around is at a fairly steep grade on the one side so that makes moving snow a little difficult while turning, but not impossible.
Ping
BX2370-1
Dec 25, 2018
335
300
Troy, Ohio
Sam,
I run the same setup on my rear blade. Never needed gauge wheels. Just make sure the blade pivot post is plumb with blade fully lowered. That way when it’s pivoted left or right, it’ll stay make contact with ground across the entire width.
For gravel, I’ll run the blade like you show and push. Or, rotate 180 and drive forward. With the convex side of the blade pointed in direction of travel, I find I move very little if any gravel.
HTH
Regards
OrangeKrush
Nov 15, 2020
1,044
517
Indy
Nice.. who ever came up with this idea needs commended?
Simple but effective! Thank you!
Sam,
HTH
Regards
thanks for the tip? I’ll let my neighbor know about this for his gravel drive.
sam24and48
BX2200
Feb 19, 2018
30
11
Goshen, IN
Yeah it was an awesome idea. I had to shop around a couple TSC's in my area as a lot were out of the 3/4 in thick mats. As another tip I just used a new box blade and cut it, worked really well especially with something like a 2x4 under it above the cutting line. The mat would flop down as it cut and almost separated by itself as i cut. Probably did 3 or 4 passes total.
JWool
B2650HSDC FEL & Front Snow Blower, ZT-Z421, GL11000 Generator
Dec 29, 2013
97
17
Northern MI
Same here I ran that same setup for a couple years, works pretty good, last year I switched to a UHMW POLY CUTTING EDGE.
3,271
That is pretty cool! I would like to increase the width of my backblade for snow removal, and had not thought of doing something like this. No asphalt or concrete here, but the added width would be helpful. I suppose I could do it with metal in my case...have to think more about it...
sam24and48
BX2200
Feb 19, 2018
30
11
Goshen, IN
So I was just doing some dinking around on amazon and harbor freight to see if anything spurred some inspiration. I have totally avoided trailer jack products as I assumed they wouldn't cut the mustard. But look at this picture I just came across at the following link. Would that be possible with one set on the main shaft of the rear blade?
https://www.amazon.com/dp/B084P9MZRG/ref=sspa_dk_detail_6?psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEzME1QWE1aTTU5OEs0JmVuY3J5cHRlZElkPUEwNDk4Mjg1MlRHV1dJRldVSTg2QyZlbmNyeXB0ZWRBZElkPUEwODU5NjQyRTFGSVA0Sjg1REdBJndpZGdldE5hbWU9c3BfZGV0YWlsMiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
sam24and48
BX2200
Feb 19, 2018
30
11
Goshen, IN
Also if you look close you can see he is using the pvc pipe method on his rb2060 in that picture as well and that looks like gravel underneath.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,848
2,257
Near Lancaster, PA, USA
I’ve used a squeegee on a couple blades and might suggest:
We have best luck with wear when using the tread from old tires. Tougher than horse mat.
I would prefer more support behind the rubber. It looks like the rubber will bend back and you will drag the cutting edge in the gravel.
OrangeKrush
Nov 15, 2020
1,044
517
Indy
I could see this happening on the larger heavier blades but my BX blade probably not a problem. I see what you’re saying though..
OrangeKrush
Nov 15, 2020
1,044
517
Indy
Is this the 6’x 4’ or close to it? My buddy bought something from there for a small truck bed mat, really thick and heavy for about $40 I think.
Orange1forme
B2650 HSDC, filled tires, wheel spacers, B2728B , LA534A FEL, 3rd valve kit
Dec 1, 2018
398
61
Wa
I was going to suggest looking at the pvc method.
OrangeKrush
Nov 15, 2020
1,044
517
Indy
Can anyone tell me how the pvc is attached, I can't see it that well in the photo.
Fatfenders
LX2610 HSDC, LX2980 64" Commercial Snow Blower, FEL w/60" QA bucket, BB1260 Box
Dec 1, 2019
60
36
Tomahawk, WI
I also cut up a stall mat and attached it to my blade. I ended up with 8 - 6' strips, enought o last me for a while. Haven't had any snow to try ot yet, but thought about running blade backwards until a little snow base was built up.
Orange1forme
Dec 1, 2018
398
61
Wa
It is cut lengthwise and then use a mallet to pressure fit it on.
There are some youtube videos on this.
OrangeKrush
Nov 15, 2020
1,044
517
Indy
Thank you! I think I may have a piece of pvc out there somewhere but I think the rubber pad sounds like the way y to go. PVC may be free to try though.😊
sam24and48
BX2200
Feb 19, 2018
30
11
Goshen, IN
So I've been doing some work on this. here are some pics of what I have so far. I'll try to give a little more detail once I have finished if people are interested. Crossing my fingers that it works.
ayak
L3301 HST
Feb 16, 2018
714
1,042
WV
My thanks for posting this idea. It used to be during winter, the gravel and grass became one during winter plowing and I lived by ‘hey, that’ll grow back’.
So I picked up some 3/4” horse stall mat from TSC, ordered some longer plow bolts thru Bolt Depot (these had been hard for me to find) and it worked flawlessly. The mat edge skipped right over the rock and when I got stupid and went into the grass, it even skipped right over the grass too.
