B6100 oil nub removal from block
torch
Jun 10, 2016
2,596
841
Muskoka, Ont.
Looks like a brass MIP (male iron pipe) to compression adapter. It should unthread by turning counter clockwise.
5,144
941
I think he is referring to the pin pipe in the top of the head.
I recall NIW discussing these pins a while back.
NIW said:.
That pin pipe moves oil from the block to the head for lubing the valve train.
Putting a dowel pin in place of it will destroy the top end.
Not putting a pin pipe in it will likely cause it to leak oil.
I think the pin is just dropped in like the dowels which locate the head.
Likely pull out with vice grips.
SidecarFlip
Banned
550
10-4 locating hollow dowel pin. Should be a light press fit. If it don't want to come out with light persuasion, take a propane torch and lightly heat the surrounding area to expand it and it will come out.
torch
Jun 10, 2016
2,596
841
Muskoka, Ont.
Ah. Well that makes sense.
southernpiper1
b6100
Kinda tried that but thanks. This is the thing on top. Not the side and it seems to be steal. Didn't want to come and obviously it isn't rusted. Don't want to bugger it up. Anyone have any experience with this? You can't mill the block without taking it out or grinding it down.
southernpiper1
b6100
Sidecar flip, thank you, missed your response initially. Sounds good I'll give it a try tonight. I think it will take the heating because it's a little stubborn.
Thanks again.
Pau7220
Aug 1, 2017
785
277
Scranton, PA
When you say milling the block, you have this completely torn down for overhaul? I ask because the cast iron and silicon carbide dust I see on the pistons and in the pushrod bores from the sandpaper is concerning. Milling the deck may require a shim. NIW or lugbolt can offer more guidance on this.
SidecarFlip
Banned
550
Whatever you do, don't grind it down. Has to be there are it feeds oil to your rocker arms.
southernpiper1
b6100
You're ahead of me. I just asked that question. The area I live in has minimal internet and everything goes through my phone. I'm missing messages due to the small screen. Your correct but I do have the means to make it flat. At this time both, the head and block are within 1/1000th of flat. I just asked if I need a spacer and how do I tell what thickness. I guess I'll need to know where I get one or more. Do they come in different thicknesses or do you stack them?
You all are great.
southernpiper1
b6100
You're ahead of me. I just asked that question. The area I live in has minimal internet and everything goes through my phone. I'm missing messages due to the small screen and learning how to navigate the site. Your correct, but I do have the means to make it flat. I have a granite surface plate and straight edge. At this time both, the head and block are within 1/1000th of flat. I just asked if I need a spacer on I guess the same forum. How do I tell what thickness? I guess I'll need to know where I get one or more. Do they come in different thicknesses or do you stack them?
You all are great!
I forgot to answer your question. No, I just have the head removed. I'm going to attempt to TIG the crack in the block. It appears to be located in a non vital area. This was a running engine but had oil in the coolant. You can see where the freezing raised the crack a couple of thousands. This is me buying other people's problems.... Final picture is the block prior to welding. If this all fails, I'll end up parting it out which I hate doing. Too neat of a little tractor.
You all are great.
You all are great!
[/QUOTE]
I forgot to answer your question. No, I just have the head removed. I'm going to attempt to TIG the crack in the block. It appears to be located in a non vital area. This was a running engine but had oil in the coolant. You can see where the freezing raised the crack a couple of thousands. This is me buying other people's problems.... Final 3 pictures are the block prior to welding. If this all fails, I'll end up parting it out which I hate doing. Too neat of a little tractor.
