Hydraulic fittings on loader won’t go back on
troverman
Jun 9, 2015
1,178
264
NH
I have taken the loader on and off without issue several times on my one year old L4060. I had taken it off two days ago, and in trying to put it back on two of the four hydraulic quick connects will not go back on. They are the bucket curl and dump fittings. All of the valves are free on the tractor side but not on the loader side. I need to hook them all up in order to get the loader reattached. Loader is sitting on flat pavement. Thoughts?
SidecarFlip
Banned
558
Both my loaders will act the same way at times... Easy (but messy) fix. Take the loader connector in your hand and take a small round, flat faced punch and a hammer and whack the rod / punch against the internal poppet in the coupler. That will relieve the pressure and allow you to couple them. Be apprised, the fluid will squirt out and it goes everywhere, including on you.
I have my wife hold the coupler while I whack the poppet with a rod and hammer so I get oiled and she don't.
I do that quite often.
Has to so with temperature changes causing the fluid to expand.
troverman
Jun 9, 2015
1,178
264
NH
Thanks Flip...I’ll try it tomorrow when I’m back on site.
200mph
Mar 3, 2017
1,228
65
PA
Can always loosen the fitting a bit to allow some fluid to escape.
BigG
Sep 14, 2018
1,951
773
West Central,FL
There are several different tools that make it easy to relieve the pressure.
SidecarFlip
Banned
558
Best is the easiest and least cost. Punch, hammer and a willing partner of course. Far as being environmentally correct, a quick squirt on your dirty shirt is all well and good and hydraulic fluid, unlike motor oil, washes out.
BAP
Dec 31, 2012
2,994
1,097
Try this morning while it is cold. You may find that the fluid has contracted some in the cold and they go right on. I find that if I take my loader off and it sits in the sun, the fluid expands and I can’t get some of the couplers to connect.
3,237
I prefer to use a plastic screwdriver handle rather than metal to metal contact.
May make no practical difference, but some of my connectors have a ball inside that looks like it can rotate, so I do not want to scratch it.
troverman
Jun 9, 2015
1,178
264
NH
I'd like to, but the problem is I'm on another site until 12:30 today. I'll try that first though!
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,710
2,040
Near Lancaster, PA, USA
Use a piece of hardwood or plastic. I did damage with a piece of allthread. I modified a small cheap grooved pliers and cut pieces of hardwood from an old axe handle. I'll snap a pic next time I'm in the shed.
Edited to add pics. When in actual use, I wrap a rag around the end because it'll squirt pretty good.
SidecarFlip
Banned
558
Pioneer 'disconnect under pressure' (breakaway) males will have a semi pointed check valve in the end. Pioneer round ball are non breakaway. Kubota uses all Pioneer style disconnects It does make a difference (ball or tapered flat point as to how the internal pressure is relieved but the escaping fluid is very minimal.
troverman
Jun 9, 2015
1,178
264
NH
BAP seems to be correct. Today is a cooler, cloudy day and the fittings went right on. I did come prepared with a flat bolt to fit the conical pioneer valve to tap on, but no need. Now just fighting to get the loader pins aligned. Thanks for the help.
nbryan
Jan 3, 2019
1,316
835
Hadashville, Manitoba, Canada
This drove me nuts too trying to connect the loader in the friggin freezing cold sometimes, and releasing pressure on the loader lines by forcefully compressing the ball valve-end is the only way. Putting a rag over the end first helps keep the mess down.
I bet higher-hour units don't lock up as much, can seep enough.
