New rebuilt ZD21 hydraulic pump and both drives overheating
Merd
ZD21, M9000
Aug 6, 2020
Kentucky
I have a 2004 zd21 with 1400 hrs on it. The left drive motor went out price was $1900 parts only. Charge pump, both drive units and add on oil reserve parts about $2600. opted for all parts. Did own work with help from a friend and repaired. New oil, filters ect... Problem first use: couple hrs mowing and charge pump was about 275 degrees hot. Does not seem good. How hot should pump and drives run? Any help or suggestions greatly appreciated.
3,916
2,561
You could try adding an external oil cooler. The problems you are experiencing are typical for that machine/model/years and is a Kubota design problem. Sorry for the bad news. If it was me and I was using it for commercial use I’d be trying to sell it and buy a post 2008 ZD326 or 331. It’s already sunk costs so the most practical answer is to keep on using it until it breaks down, then sell the machine as is.
Merd
ZD21, M9000
Aug 6, 2020
Kentucky
I appreciate your response, but I've had the machine for 16 years and would like to use it another 16. Spent a lot for parts and would like to make sure everything I've done is correct. Still running hot so I'm going to change filter and suction strainer again see if that helps. thanks once again
9,186
Look at the pressure regulator portion of the setup.
9,186
Here is the pressure relief valve:
You need the WSM to know how to test it.
5,501
2,208
need to get your hydraulic pressure test kit out & start digging in, and comparing to the proper WSM for your machine.
flow + pressure = heat.
Did you clean the suction screen? Did you replace all of the o-rings on the pipes? What fluid are you using? What filter are you using? Is the system fully bled and full? could there be a problem with the deck lift section?
