Air lock
Beaux
Kubota 4310
Dec 11, 2019
Pine Grove, Louisiana
Changed fuel filter on 2002 Kubota L4310, removed filter cup, filter and o-rings. Cleaned cup and spring, replaced small o-ring, then put spring into clean cup with o-ring on cup. Reinstalled filter assembly but did not completely tighten, I turned fuel valve on let filter bowl fill with fuel, turned fuel valve off and tightened fuel bowl. Turned fuel valve back on/ open, started tractor ran a short period then tractor slowly stopped running/died. All help for this ( Diesel Green Horn) appreciated. Oh, I watch video from Orange Tractor talk and followed his instructions...apologize for long post.
i7win7
Feb 21, 2020
3,259
3,796
Central, IL
Not familiar with L4310 , have a B and BX
The injector pump should have an air bleed screw next to fuel inlet. loosen screw, if fuel tank is above engine - gravity should bleed out the air. If tank is lower and you have electric fuel pump, turn on key. Tighten bleed screw when fuel comes out and try starting engine.
5,138
938
Are you following the bleeding procedures as shown on the attached page from the WSM
2,612
1,131
After you change the filter, you need to open the "Jet Start" bleeder (#80) and crank the engine to bleed the air from the filter to the injection pump. When the engine starts, close the valve.
You now need to open the jet start and try cranking the engine. Crank for 10 seconds and let the starter cool for 1 minute. If it does not start after several tries, you will need to loosen one or two injection pipes at the injectors in the cylinder head and crank it until you have fuel there.
If the engine starts with the pipes loosened, shut the engine off and retighten them. Don't tighten them with the engine running as you could get diesel fuel injected into your skin.
Beaux
Kubota 4310
Dec 11, 2019
Ok, located air bleed screw, fuel tank is above and full of diesel, going out and opening air bleed screw gonna wait 5 minutes to see if fuel shows up, if not then try electric fuel pump if I have one. If no electric pump then what, crank engine over till fuel shows up?
Jim L.
817
Follow directions in attachment that Dave posted. Don't need to wait 5 minutes; don't need electric fuel pump. Crank engine without overheating the starter. Open throttle up about half-way to feed fuel rather than idle. Have faith.
5,264
Are you 100% sure you turned the fuel shut off back into the on position?
I know I've done it and it will act just like you stated.
Beaux
Kubota 4310
Dec 11, 2019
where does fuel come out from?
Beaux
Kubota 4310
Dec 11, 2019
Thanks to Everyone, I opened bleed screw/valve, cranked engine over Engine started up, let it run just a bit, closed screw/valve, engine is running as should. Thanks again for all the help.
2,612
1,131
Your tractor does not have an electric fuel pump, it is mechanical. It will only pump while the engine is cranking / running.
Read post #4 above.
grantf
STV 40 tractor
Jul 27, 2020
Auckland New Zealand
Read post #4 above.
I have a similar problem on my STV40 tractor, the tank ran dry but it was refilled and after some cranking it started OK and ran for perhaps 10 minutes, a week later it refuses to start despite much cranking.
I removed the water filter bowl and fuel was flowing freely by gravity as the tank is above the engine. I tried cranking with the air bleed valve shown in the lower left corner of the attached picture open to no avail. I even backed off the nut on the union behind the bleed screw and fuel was flowing freely. I tried cracking an injector nut at the outlet of the pump and despite much cranking no fuel is bleeding out at that point. So in my mind fuel is getting to the pump but no further. To the best I can figure there is no decompression lever. Reaching the injector nuts at the cylinder head end is going to be a mission so I'm keen to avoid that if possible. A local agent said to check the fuses as it may have an electric fuel pump. I will look at that today,. In the picture there is something in the LH lower corner that has wires going to it. It looks like a relay, or maybe a solenoid. Sorry for the long and wordy posting but any suggestions appreciated. PS the manual says to check the slow blow fuse for the stop solenoid, it is located in the battery bay so I will check that today.
Thanks in advance.
grantf
STV 40 tractor
Jul 27, 2020
Thanks in advance.
Well no luck so far, the fuses are all OK, I have cranked it plenty with the air bleed open, I think I need to get access to the injectors and try and bleed at that point. But fundamentally no fuel sees to be getting to the injectors.
