Need some advice on B9200 HST.
Need to replace the coupling on the propshaft. I split the tractor at the bell housing, got the clutch release bearing off.
From the parts diagram attached I was able to remove the roll pin, Item 100, that attaches the coupling to the transmission input shaft.
The coupling, Item 20, will not pass through the bell housing. Can't figure out how the coupling is attached to the prop shaft.
Any ideas or advice ???
