put front end loader on tractor last night l4200
ASTER
115
ROSEDALE LA
put front end loader (la650a) on tractor last night l4200, everything works good on front end loader, but the 3 pt only works when im moving around the joy stick, i have the center line up an down, if your facing the button right side in the inlet an left side is the outlet.... an the lower right is power beyond, i have all three hooked up in the right placces on the front end loader am i doinging inthing i am doing thing wrong
also im trying to find out what la650 to get a boom seal kit the boom cylinders 32mm
5,257
1,043
It would be helpful if you posted the page from the manual you used to determine what hose went where as there are no L4200 WSM available on line.
How many hoses are on your loader valve? 6 or 7.
wgator
L4701HST, FEL and other stuff.
Jul 28, 2018
482
147
NC
Dave, attached is the hydraulic port hook up from the operators manual (available on kubota books). If I understand his explanation of how he hooked it up, all three lines appear to be wrong at this port.
5,257
1,043
Please look at the initial photo with my added markings.
I am looking for feedback on how I read the manual's instructions.
The owner's photo is misleading as the center screw is set horizontal but he says he has it turned vertical.
He has hoses in the wrong places as you have said.
hope to float
L3450
Feb 18, 2018
485
61
Ireland
I have the same valve on mine. I'll have a look tomorrow.
Did you turn the slotted screw in the centre? Mine is 45 degrees one way with loader connected and 45 degrees the other way when the loader is off the tractor
wgator
Jul 28, 2018
482
147
NC
Dave, I agree with your marked up pic according to the instructions I posted.
ASTER
115
ROSEDALE LA
thx this worked good
ASTER
115
ROSEDALE LA
its been working good..... i have a quick ?.... this what i have is hydro block on tractor line power beyond point going ran to front end loader power beyond point... the ? is can i cap both side... someone told me it helps with flow psi....
8,758
No you can not cap it, as you'll blow the seals out of the pump.
5,469
2,163
with the complaint of "3ph doesn't work unless loader control is actuated" is almost always due to incorrectly installed hoses. A lot of times it's the BY hose and TANK hoses swapped.
