FEL BF300 Stands
Gosney541
L2501-B8200
Apr 8, 2020
15
Bend OR
Can anyone takes some pictures of their 4 stands for there BF300, i only have the 2 that go on the bucket and called to see if i could get the rears and looks like they don't make them as of beginning of the year, my luck.
8,760
The rears are simple, they are just rods help keeping from tipping back.
Did you look on the inside of the loader arms? They sometimes hide them under the hydraulic lines.
6,633
If you don't have/can't find the rear braces you can make some. You will find a square hole (I think it's on the loader tower foot). A rail road spike will fir into that hole with virtually no slop. Get a piece of steel, can be any shape size to weld to that spike. Need to measure how long it needs to be and weld it at a slight angle outwards so it clears everything below. Might even weld a flap plate/washer to the bottom to keep it from sinking into dirt.
I may have one laying around. I'll look in the morning and take a picture if I find one.
Gosney541
L2501-B8200
Apr 8, 2020
15
Bend OR
Found one! If you have more questions, just ask. The basic rod is square stock, like 1/2" or 5/8".
Thank you sir for the pictures, this helps alot. i will go find a metal fab and see if its something they have time for.
Is the curl portion 6 inches long? im just guessing
