Slv65 error code e026 wont start
200mph
Mar 3, 2017
1,228
65
PA
Do you have a specific question you'd like the forum members to comment on?
This was from a SVL95 manual, so act accordingly.
E: 026 CRS CAN communication - --- Immediately contact your local
dealer
Brick Axelrod
L5460, BH92, RCR1872, FDR2572.RTVX1100c
Apr 12, 2018
135
9
South Carolina
It’s a CAN communication issue. It’s may be a bad module, or if you were banging around a plug may have come undone. Code says to contact dealer. Let us know what they find so others can benefit from it.
ehenry
BX22, FEL, BH, 40" pto tiller, 42" Bushog Squealer, pto hole digger, B7300 w/60"
Mar 25, 2014
363
92
Canton, MS
Are Kaffinated and Asacooper89 the same person?
Fasteddy1
Torrington
You ever fix problem I have a ssv65 doing same thing
AsA Ed from the dealership have checked all connections and ohm wires like instructed by Kubota tech. All appear good ! got back in touch with Kubota tech. waiting for a answer from them on what to do next. Bye the way the other SS75 did have a skip but all codes have gone away and I ran the machine with no problems unloading trucks? The skip is not apparent anymore.
Fasteddy1
Torrington
Asa, What Axelrod is saying is what I had told you on day one. Kubota tech feels there is a bad pin in the CAN connector or pinched wire somewhere on the machine I will check that out tomorrow. Electrical problems can be real easy to find or very very hard to pinpoint. But we will find it!
