I've had this tractor running for 63 hours now. I had to overhaul the engine when I got it. I had no idea how much I needed a tractor until I got this one.
Yesterday The right front wheel started acting like it was going to seize. It would stop for a second and as soon as it got the pressure from moving forward it would free and roll. It rolls good and straight. When off the ground and spun it feels pretty smooth. The axle seal is leaking but it seems like no play in the berings.
I pulled the tire and axle hub today. The case has some metal shavings in it but no pieces like chipped or broken teeth.
The previous owner was saying how he just put wheel seals in this side before I bought it. I'm thinking now that may have been the problem. There are 3 shims spacing the wheel hub from the pinion.
After pressing bearings in and out for the seal could it be spaced too far apart and need less shimes to ride deeper in the teeth?
