Pedcock thread size
RebuildD1105
D1105 engine
Dec 15, 2019
California
Searching for the thread size for water drain cock hole in a Kubota diesel D1105-E engine. My water pedcock broke off and I need to chase the threads prior to installing a new part. I believe the replacement part is Kubota 15841-73020. I purchased a replacement that came in a bag marked as Onan 185-5490 Cock-Assy. Do you know this thread size or can you direct me to who might?
dlundblad
G5200, L2501, ZD1211
May 16, 2009
504
IN
Can you take the part to the hardware store?
Should be a tapered pipe thread.
5,163
Can't say exactly what yours is, but many in the automotive field us 1/8" NPT (National Pipe Thread). I have also seen 1/4-28 machine thread, and checking the O'Reillys website, I see the following sizes listed:
M10-1.25
M12-1.25
M14-1.50
5/8-18 Inch
This leads me to believe that there is no universal size. Back in the 1960's, the common size was 1/8 NPT. If you have to rethread the fitting, then the choice is yours. Just pick the one that you can get a tap easily, and won't be too large.
https://www.oreillyauto.com/shop/b/cooling---heating-16773/radiator-drain-petcock-11358/fc5e9fcf4fd6
10,960
It's probably BSPT, it will be the same size as NPT but a different thread taper.
4,184
Take it to a machine shop if you don***8217;t have a thread-gauge, and they can use a thread gauge to tell you what it is. (Most likely 1/8 NPT. One way to determine is to take it to a hardware store and see if it will thread into a 1/8NPT fitting.)
10,960
Most likely 1/8 or 1/4 BSPT, Kubota engines almost never come with NPT fittings. ;)
5,187
What is a "Pedcock" ?
