M7040 No power to dash, no start
Palominofarmer
Kubota M7040
Dec 2, 2019
VADO
Ok guys, time to do that last thing men do...ask for help.
I have a 2011 M7040. A couple weeks ago the tractor would not start, had no power to dash. I charged up the battery, no help. Next day I walk out thinking I'm going to dig into this thing, starts right up like normal. Finished my chores, turned tractor off, wont start again. Ran a test light to the key switch and I'm showing power but when the key is turned to start the power doesn't transfer to any other wire. Has to be switch right? No. Ordered brand new switch from kubota, installed and the damn thing cranks right up. problem solved? Nope. I started it this morning with no problem, tried to start this evening and back to square one. All fuses look good and basically the damn thing starts whenever it wants. The light comes on with door open so I'm definitely getting power to the cab. I'm not sure where to go from here. Any help is appreciated. Thank you.
Roadworthy
L2501 HST
Aug 17, 2019
1,647
530
Benton City, WA
Clean both battery terminals inside and out. Make sure the ground side of the battery has a good clean connection to the frame of the tractor. Start with the easy really basic stuff.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,298
184
Coyote Flats,Texas
Welcome to OTT
Ditto what Roadworthy stated. Have you cleaned/tightened all four(4) battery cable connections?
5,255
1,060
I have attached the wiring diagram for the start circuit and the troubleshooting chart.
Start with Roadworthy's suggestion.
In the start circuit there is a 5 amp fuse, start relay, neutral safety switch on shuttle shift, pto safety relay, and lastly pto switch.
After cleaning the battery connections, my next step would be to jump the starter to make certain the most basic component is working.
If you do not know how to do the starter jumping safely please ask first.
leveraddict
Apr 1, 2019
905
594
NEPA
I had a similar experience! The plug going to the starter that snaps together was still snapped together but had some back and forth play! Just enough to disconnect but still snapped together! Thats one sloppy plug on my BX! Lucky I found it just before the dealer was about to pick it up! I still had power to the dash though.
Palominofarmer
Kubota M7040
Dec 2, 2019
VADO
Cleaned all battery terminals, checked all ground connections. All fuses look good, I even pulled out ever single one and cleaned all contact points. I had the issue with the PTO switch before but it didn't prevent power to the dash lights. Imagine turning the key as if the battery was completely dead but the battery is fine. The couple of rare times it decided to start it started very strong with no hesitation. It started yesterday but I didn't move the tractor at all, didn't change gears or even sit in the seat. I cranked it, let it run for a bit and shut it off. Later that evening there was no power again but I have the cab light come on.
5,255
1,060
A few questions so I can better understand.
When the tractor is unresponsive are you saying the only thing to work is the cab dome light? The upper front and back lights wont work? The headlights wont work? Radio wont work?
Is there power in the cigarette lighten socket?
AllDodge
M9540 RTV1100
Jan 19, 2019
199
South Central, ky
You need a voltmeter, a test light will light at lower voltages
So with key ON, there is no radio and windshield motor does not turn ON?
Palominofarmer
Kubota M7040
Dec 2, 2019
VADO
Power to dome light. No power to cig, radio, A/C, Dash lights, work lights front or rear, wipers, headlights, guages.
This morning I went to start it, started fine, no issues at all. Didn't move it at all or mess with anything at all. Just start, ran for a few, turned it off. Took my daughter to doc. Appt., went to start it and nothing again. When it starts, it starts without issue. When it wont start I get absolutely nothing when I turn the key. It's about as random as it gets.
AllDodge
M9540 RTV1100
Jan 19, 2019
199
South Central, ky
Its wire or connection from Starter to Fuse to Key. Something in the chain has some corrosion or bad connection, my guess is corrosion.
5,255
1,060
Do the 4 way flashers work when everything is dead?
They are on the same circuit as the dome light which means power should be always there.
Palominofarmer
Kubota M7040
Dec 2, 2019
VADO
Ok gents, I had some time today to dig into this thing. I checked every fuse, relay and connection. Hot tested everything. Power to new key switch, starter, all fuse boxes have juice. Disconnected all pigtails and cleaned them out. Removed all relays and wire brushed the contact points. Swapped all matching relays to see if there is any change in function. Absolutely no luck at all. Neighbor has a new tractor, swapped batteries (yes, I have neighbors like that. It's awesome). No change at all. Grounds are all good. Traced what I could in the wiring harness for shorts or breaks. I came up with nothing...Pretty mechanically sound. Electrical is not my specialty but I'm not a novice either. Anyone have a new idea of what I'm missing?
Palominofarmer
Kubota M7040
Dec 2, 2019
VADO
No, dash is dead. No flashers, gauges, horn doesn't work, no headlights or individual turn signals.
5,515
2,231
If it's a cab model, pull the floor mat out, you will see a bolted-in tunnel. Remove it. Underneath are the wirings. Disconnect the connectors and clean them and see if that solves your issue. I've seen some of the connectors so corroded that they wouldn't come apart without damage; in that case, cut them off and hard-wire them; unless you have access to new connectors and pins then just replace them.
AllDodge
M9540 RTV1100
Jan 19, 2019
199
South Central, ky
Need to be using a voltmeter, test lights just says there is something there.
Can check voltage drop by placing a meter probe on each end of a single wire. Should read next to nothing, finding more shows possible corrosion.
Remove and try to look under the insulation jacket at the wire ends. The jacket can look great and may be badly corroded under
Palominofarmer
Kubota M7040
Dec 2, 2019
VADO
Buddy, you are a life saver. Burned connection. Going to run a jumper on them and let you know how it goes. Hopefully this is it.
Palominofarmer
Kubota M7040
Dec 2, 2019
VADO
Ok I have power to dash and she cranks but no start, no headlights, no blinkers, brake lights, horn, etc. Progress has been made. Got late so I'll mess with it tomorrow. Thanks everyone for the help. I'm sure I'll have it back in service tomorrow.
Palominofarmer
Kubota M7040
Dec 2, 2019
VADO
Hey man, you were spot in. One of the connectors was burned up under there. Hard wired everything and she starts right up now. However, I have no lights, flashers, radio, or headlights. I do have A/C, wipers, work lights front and rear. Any idea where to go from here?
