M7060 hydraulic pressure?
Itmitb
Kubota M7060
Oct 29, 2019
Leesburg, Georgia
Anyone know the factory hydraulic pressure on a M7060 rear remote valve and also on spool valve to loader? Any help appreciated!
200mph
Mar 3, 2017
1,228
65
PA
You might want to consider posting this in a "Service, Repair & Maintenance" section. You're likely not to get too many views in the "For Sale Section"
5,257
1,046
You need to appreciate the hydraulic circuit. You have two relief valves.
One on the FEL valve and a second on the rear of the tractor.
The WSM for the tractor only talks about adjusting the relief on the rear of the tractor. Fine if you do not have a loader.
Because the FEL valve feeds the rear of the tractor using a power beyond port, the FEL relief valve sets the maximum pressure the rear of the tractor can see.
The correct sequence is to adjust the FEL relief and then the relief on the rear of the tractor.
It is impossible to set the rear relief higher than the loader relief.
200mph
Mar 3, 2017
1,228
65
PA
Great clarity Dave! I'm certain the OP will value this info.
