2018 L3901 3 pt will not pressurize
Nick46304
2018 L3901 with BH77
Sep 1, 2018
yelm, wa, usa
I bought this tractor at the end of 2018 and love it...I bought it with a FEL and a BH77 backhoe installed shortly after I installed a hydraulic 3rd function valve. I have never hooked up anything besides the backhoe to the the rear. I bought a wood chipper this passed weekend and installed it, it ran like a champ... but when I tried to raise the 3 point it wouldn't do anything... I read through the manual and made sure I tried all positions on the raise and lower lever and I made sure to open my flow knob under the seat. I removed the chipper to do some more looking around and I can grab the 3 point and move it up and down ...almost as if it were not pressurized or in float mode...not really sure where to start... any suggestions?
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
When you took the backhoe off did you take the long hose on the tractor and plug it into the female connector on the tractor to complete the loop?
BAP
Dec 31, 2012
3,009
1,109
I recheck that hose to make sure the coupler on the hose has seated properly.
Nick46304
Sep 1, 2018
yelm, wa, usa
Wolfman, could it be a disconnected feedback rod?
I looked up what a feedback rod is, and I saw a good blown up diagram and instructions on to adjust it...when looking at the diagram it looks like the feedback rod is mechanically connected to the control lever...is that the case? because when I move my control lever, the feedback rod does not move...also in the instructions on adjusting it says to adjust the relief valve...but nothing in the picture pointed to what that is...anyone have a pic of said relief valve?
Sent from my SM-G965U using Tapatalk
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
Can you post some pics of your loader valve, the hydraulic block under the right floor board and hoses? Is it possible the dealer didn’t plumb it right? I would think you would have other issues but maybe somebody might see something. I would be surprised a machine that new would have an issue like that, but anything is possible. I have a GED in hydraulics from OTT, but I just installed a bh77 on my tractor a little over a month ago. My tractor pretty similar to yours I believe.
Nick46304
Sep 1, 2018
yelm, wa, usa
here are some
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
Follow this hose to where it comes from and take a pic if you can
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
Those two hoses need to be swapped,your return from the loader is feeding the power beyond to the 3 pt,your back hoe return is plumbed into the tank return.
BUT... I don’t know how the third function is tied into your system. But still I don’t believe it’s plumbed right
Nick46304
Sep 1, 2018
yelm, wa, usa
would it be beneficial to show u the plumbing of the 3rd function,because I believe it was the way u are stating until the 3rd function got put on
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
Yes. Those hoses I pointed out need swapped because where the loader return is going is feeding your 3 pt and it won’t work. The only question would be if they have the 3rd function plumbed right
Nick46304
Sep 1, 2018
yelm, wa, usa
the one I have my finger goes to the loader valve in the other pic with my finger on it....the hose on the right of the 3rd function is the return from the backhoe
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
You need to swap those two hoses I pointed out earlier. The hose that your finger isn’t on is tied into the long hose to the back hoe, right?
