3pt or 12V salt spreaders
hockeystewey
2017 BX1880 w FEL, 54"MMM, 2019 BX2816 50 " snowblower
Dec 12, 2017
114
NY
Hey guys anyone on here use a 3pt or a 12v spreader for salt on the driveway? I am looking for some recommendations, thoughts, ideas,pics,etc......
Thanks fellas!!!!!!!!!!!
Digger Dager
M59 TLB, B3200 w/front snow blower, 3 @ ZD326 62" rear discharge mowers
hockeystewey,
We bought a Land Pride FPS 700 for the back of our B3200, holds about 550# of sand, runs off the rear PTO. Works very well for the 2 miles of gravel and paved drives we have. I have used it a lot this year with the winter we have had.
The only problem we have with it, it is made for fertilizing fields, made to spread material up to 50' wide. We need to spread 10' to 15' wide, also with a cab on the B3200, I couldn't reach the controls for the discharge flow. Solution: run engine at idle and go, and installed an electric actuator to control the discharge rate.
Digger
dalola
BX2380 w/FEL & Woods RM48 RFM, Yazoo/Kees Max2 ZTR
Jun 30, 2017
316
For light duty applications, I think 12V makes more sense.
I'm in the process of fabricating a 12V fertilizer spreader that I can mount on the front of my FEL. I think you could do something similar to spread salt.
Currently looking at some ATV/UTV spreaders as a starting point.
BXHoosier
BX24
Jan 21, 2018
493
574
Indiana
I modified a pull type Scott’s spreader to mount to my Cub Cadet and used a motor and gearbox from an old cordless drill. The motor was mounted below the spreader wheel at first but salt and moisture seized up the first gearbox. It works great for salt, grass seed, and fertilizer.
jhayden
2018 L3560 cchst 805 fel
Jan 6, 2018
Dartmouth. Nova scotia
I have a 3 pt fertilizer spreader on the back of my L3560 and you have to almost completely close the shute but it works great
BAP
Dec 31, 2012
2,931
1,044
hockeystewey,
Digger
Some companies make a deflection shield that goes on to limit how far they spread to keep the sand on your road or driveway and not out in the woods.
