servicing grey tractor parts
3,063
I have a l1-285 Kabota tractor which I recently purchased and want to service. I cannot find serial numbers and would like to know what type of oil and aircleaners will suit this tractor.
alan
Alan,
if not mistaken - you have a D1302 engine, engine oil to use? I would imagine any 10w-30 oil you guys down under have for diesels will work well. Synthetic oil if you like. OR perhaps a 15w-40, the real question is the temperature ranges the tractor is used in, that might sway the weight of the oil to start with.
Air filter.......
I believe this is the right one:
http://www.kubotaparts.com.au/index.php?route=product/product&product_id=977&search=air+filter
Your engine is the same as the North American D1302 that is used in L275
11,106
Alan,
Sorry to say you are mistaken
The L1-285 has a V1512 engine
Air filter your probably right on.
Negative, if anything it would be closer to the L285 which has a V1501, But the L1's are newer than the L285's and are more in line parts wise with the L2050, L2250, L2550, L2850, L3350 series of tractors.
3,063
In my digging - I must have transposed a number or 3:D:eek:....
or the info I stole was wrong!
THank you NIW !:)
100 td
B21TLB (B21, TL421 & BT751) Toyota SDK4 T116 Bobcat
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
Any 15-40 diesel oil, any tractor/hydraulic oil if it's non HST/GST. Mobilfluid 424 is equivalent to Kubota UDT and available at oil depots.
Filters, clean them up and see if you can get a part number off them.
Give Sota tractors or Midway sales a ring, they may have filters/specs/manuals available for your machine.
http://www.sotatractors.com/
https://www.midwaysales.com.au/
EDIT:
Please note: we are unable to accept parts enquiries by phone, from customers that didn't buy a tractor through SOTA. Please email SOTA, using the form below and our service staff will respond as soon as possible. We appreciate your understanding.
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
Your engine specifies 10W-30 but Kubota released a statement that 15w-40 can be used, probably as long as temps don't go to low. I can't recall where I saw the statement, should look it up I suppose. I use 15W-40
Here is a Jap user manual with filter part numbers in it, oil quantities, greasing points and lots more if you can read Japanese!
Also noted is the engine - V1502-DI
Plus a Jap electrical diagram!
Does your tractor have a working Monroe-matic system?
http://www.jnouki.kubota.co.jp/jnouki/manualdata/30400-1921/30400-1921-5.pdf
