D902 injection pump install/Nautique1228 post July 2014
TopCat1948
Grays
Dear All,
Looking for some advice/Help on: removal and refit of a Kabuta D982 injection pump,
I Googled what I was looking for and the picture and half the writing came up from the post from member: Nautique1228 which was posted July 2014.
I'm looking for that article as I want to read the full instructions to the right of the picture
Can anyone Assist on where I would find this article in full,
Please see picture I've attached
I'm working on a Kabuta D982, but I believe that the diagram and instructions on how to install the D902 is just what I'm looking for
Kind regards
TopCat48
100 td
B21TLB (B21, TL421 & BT751) Toyota SDK4 T116 Bobcat
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
Is there not enough available in the original post #4?
http://www.orangetractortalks.com/forums/showthread.php?t=15378
There is a 782 engine wsm on the net somewhere, it's injection pump is the same as a 902 I believe. There is a couple of diagrams and pictures in various pages in this mower wsm which may help.
http://www.kubota.cz/data/manualy/gr-2100-wsm-en.pdf
http://www.kubotabooks.com/AutoIndex/index.php?dir=Mowers/&file=ZD-21-28-wsm-en.pdf
8,527
How did you determine it's a D982?
I ask because I've never heard of a D982 and there is Zero listed by Kubota for that.
Perhaps it's a D782?
What is it in, or what is it running?
And changing the injection pump on any Kubota is just about the same, remove the lines, unbolt it, and pull it out, keep all the shims for use with the new injection pump, reverse for install.
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
I'm guessing he has a 902 and he's reading the 0 as an 8, either way 782 or 902, same same.
I couldn't find my 782 file on the net
I looked thru my genset and pump files and I found a super-mini file with a 782/902 with pics, then searched the net for it, this should help him I expect..........
http://bestgenerator.spb.ru/toyo/pdf/engine/manual-wsm/00-kubota-sm-series-wsm-manual-enu.pdf
While I think the differences would be subtle, there is an earlier version at kubotabooks.com as well.
2,779
I think the OP is talking about this:
https://www.ebay.com/p/Kubota-RTV-900-Fuel-Injection-Pump-16006-51010-D902/1323996842
