How much will it lift?
Stob
37
VA
I have a L2550 with a LA450 FIL. Any idea what the lift capacity would be? I'm thinking on getting a bolt on hay spear and going with round bales instead of small square bales. But I need to make sure I can lift them, or the whole idea is a bust!
2,219
what i can find = 882 lbs @ pin:)
boz1989
B2910 fel 60 mmm, Land Pride rb1572
Jun 10, 2015
269
Portland, MI
I know another farmer that sells hay. he had a lady that wanted smaller bales, so he asked how big and adjusted the baler for that. Not everyone would do this, some balers won't, but if you were to ask & pay for x# in advance. Just another option.
Sent from my LGMS330 using Tapatalk
jpf
120
butler, ga USA
when I was looking at tractors the dealer told me whatever number was on the arms I could double that number and that would get me in the ballpark on lift capacity.
la450= about 900 lbs.
on my 2301 it says la435, lift = about 870lbs
accurate, I think so.
B Krafty
Kubota B2650 HST
Jun 6, 2017
9
Pocatello, Idaho
Look into a 3 point bale forks. you can probably lift 1500-1800lbs with the three point and the weight will be in a better place. probably would have to roll it off the trailer and won't be able to lift it to stack it much.
Redtoorange
B2650, BH77, 63" front mount snowblower, land pride bb,fel
Apr 7, 2017
38
Ont, Canada
When I bought my 2650 the dealer said the number is how many KG it will lift so conversion at 2.2 pounds to a Kilo would put you at 990.
MadMax31
BX23S, 60" MMM
Nov 5, 2014
766
New York
882 at the pins. I cant find at the bucket edge nor the breakout force without the original manual.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
73
Rocky Face, Georgia
Here's a L3000 with LA450S, Kubota fork back plate and 42" spear.
As far as 3pt goes you'll need some weight on the back and when it comes to lifting hay the loader and 3pt are about equal.
These are 4x5 rolls from a Vermeer baler. Here are a few pics of it in action, even a night shot with chicken lights.
bxray
Bx25d
Dec 1, 2014
712
Cleveland, ohio
You can use the force x distance formula for a lever to calculate the lifting power.
900 x the distance to the pivot point.
Then divide that by the distance to the bail spear end and you will have your weight at that point.
Ray
Stob
37
VA
Bulldog, thanks for the pics. It looks like you roll back the bale right off the truck getting the weight back to the tractor. Nothing wrong with that.
I just hate taking the bucket off to move hay, cause I use the bucket all the time! And I don't have the bobcat mounting plate.......
Bulldog
Mar 30, 2010
5,440
73
Rocky Face, Georgia
Actually all those pics were loading in the field but yes it helps to roll it back because of the weight. Stacking double it's also a height issue.
You need to get one of these. Kubota style QA. Pull 2 bottom pins and set the bucket off. I prefer this over a SSQA by a long shot but that's me I guess.
