BX23 side to side deck leveling
Rebel654
B6000
May 30, 2016
14
Scottdale
I did a search for deck leveling and I see alot of folks with a bolt and locking nut for deck adjustments. I Do not have that on my BX. I recently picked up a 2005 BX23 and mowed for the first time and checked the deck and it needs adjustments. The tractor came with no manual. So is this my deck adjustment in the pick ? Also what is the bolt and spring for under it. Thank you in advance
Sent from my XT1650 using Tapatalk
8,707
INFO: When you refer to your tractor refer to it as a BX23D as there is another that is a BX23S and it's a different build.
There is one bolt and spring make sure they are the same tension, that is the balancer.
And yes the main arm leveling is done with the adjustable linkages.
Rebel654
B6000
May 30, 2016
14
Scottdale
Thank you sir, I did not know that the BX23 had different models I appreciate your help
2,827
The Bx23 is the younger brother of the Bx24 and the Bx25.....the newest baddest BX is the Bx23s......confusing ? O yes!!!!
Can you tell us the model of the MMM? mid mount mower;)
