My father owned it, then my brother, now I own it. Its old but still runs good. Not sure of manufacturing date. I'd like to know if this model will support a front end loader attachment. If anyone knows, please respond. It may not be big enough, but would like to know my options. My father had bought quite a few attachments for this tractor. The ones I use most is a Big Bee rotary cutter, and a box blade. He hid a few others in the woods so no one would steel them. So I need to cut them out of the woods to see exactly what all I do have. Still learning how to use it. I should probably put it in the shop for a tune up and general servicing.
Kubota equipped much smaller tractors with loaders so no it's not to small.
First is it a 4wd?
Does it have power steering?
If not, then you might want to hold off on putting a loader on it, makes them really hard to steer.
Now that tractor was made 1985- 1990, so 32 to 27 years old.
Finding a factory loader for it might be really hard, to took a BF400G and yes the G is important, a BF400 will not fit it properly.
You will probably find going to an aftermarket loader much easier
A loader for it will run in the range of $1000 (if your lucky) to $2500 used And $2500 + for a new one.
If you do a used loader make sure it has the right mounting brackets to fit your tractor, as most after market loaders will fit many different tractor makes and models with different bracket kits, and also make sure it has an open center valve.
