B2320 humming sound from hst
2,866
When tractor is at 1500rpm or more, I noticed a humming sound coming from hst area!
Tractor has 40 hours on it
Does the humming change "pitch" when going uphill?
Is it worse in high gear? or better in low?
Is it worse or better as engine speed is increased?
Checked fluid level?
Jtryan
B2320
Jan 17, 2016
55
Ottawa, Ontario Canada
Level is good.... it's not the hst whine I'm hearing, more of a hum I hear with tractor still and Rpm above 1500. I got off tractor to listen where it was coming from and it seems to be in hst area! Could it just be the hydraulic pump?
4,283
Most likely, they are noisy little critters, when you do your first fluid change out change to SUDT2 its not cheap but at least on mine the noise has gone way down,,
