B7200 Box Blade Size
Jasonoatv
B7200HST-D
Sep 27, 2016
Hopkins, Michigan,USA
Hi everyone. New to this group but I have really enjoyed reading what has already been posted. Thank you!
Okay here's my issue. I recently picked up a B7200HST-D with a FEL. I am looking for a decent/cheap box blade, but after looking around I feel the tractor could handle a 4' a lot better than a 5'; but my tractor width is larger than 4'. I guess what I'm asking is can I run a 5' efficiently to grade my driveway? I know I'm asking a lot out of a small tractor just wondering if someone has done the same?
2,862
If you are not going to engage the ground in a deep manner, the 5' might work.
I used a 4' last weekend behind my B7100 - in certain conditions it would spin in two wheel drive and then bog the tractor down in 4wd.
5' is 25% larger than that of a 4' er. That amount of engagement will be noticed! It really depends on the application - moving piled dirt or gravel it might be fine, cutting into packed soil........might not be so good!;):)
Jasonoatv
B7200HST-D
Sep 27, 2016
Thanks 85Hokie.
I decided to go with a 4 foot and live with the few inches of overage on each side. I hate the idea of not being able to use the blade to its full extent.
Missouribound
Jun 17, 2014
657
54
Missouri
Thanks 85Hokie.
The only problem I see is that now your tires will be in the soft ground you just dug up
TN Road Dog
L3301HST with FEL, BB1266, FDR1672
Sep 19, 2016
10
Somerville, TN USA
By now you have probably bought a 4 footer,
but,Land Pride box blade BB05 and BB12 series both have a 54 inch box available.
that might cover your tire width. models BB0554 and BB1254
Michael
