I have a single bottom blow with a left/right adjustment. After the adjustment is made you can then make it stay there from tightening a bolt (pictured).
The weld on the nut is cracking and the bolt does not want to keep the plow in position.
Im wanting to go ahead and replace both the nut and bolt.
My question is there a special bolt that I should be looking for that has a better way to grip on the end of the bolt when it makes contact rather than a standard bolt ?
Thanks
Thanks
