MMM gearbox hot to touch
Southernfarm
2014 BX25D
Jun 8, 2016
109
Southern MB
I probably have 20 hours on my 60" MMM. When I bought new and uncrated it, I had to put gearbox oil in it. I believe the stuff was standard 75w-90. Filled it until it came out the top filler bolt. Anyway, been cutting grass for about 2-3 hours today and went down to clear off the dry grass off the deck and noticed the gearbox was rather hot to touch. Should it be that way?
In the coming days I will be removing the deck and going over it, greasing it, cleaning it. Should I drain out the gearbox oil and replace? Should I put the same 75w-90 in it or put Kubota UDT in there?
8,590
Gear boxes can get pretty hot after running that long. But also, our perception is skewed when judging what's hot, and what the temp actually is by touch :) If your concerned you can always check it periodically with an infrared thermometer.
2,864
What he said ^^^^^^^^^^^^^^^^ twice as good as what I could have said!:D:)
Southernfarm
2014 BX25D
Jun 8, 2016
109
Southern MB
Never knew they could get hot at all. Wifey was helping clear off the dried grass on the deck when she noticed it, and was concerned about a fire hazard. I don't think it was hot enough to ignite dry grass but still hot none the less.
7,029
Southern Farm- I don't recall exactly, but seems my gearbox has a bolt part way up the side that indicates full. Fill from top until it gets there.
Pretty sure it's not full to the top. No room for expansion. Just double check that. They do get warm!
8,590
I know a couple folks that have had there mowers go up in flames :eek: Warned a landscaper a couple years ago, that his brand new zero turn started smoking everytime he started driving. He gave me the ol brush off. :rolleyes: Passed a burned out trailer with a zero turn on it later in the day with the fire department just rolling up the hoses. :rolleyes:
After seeing that, I make sure and blow out the mower deck before parking it ;)
rjcorazza
Mar 9, 2016
778
25
Hyattstown, MD
I do the same with my mowers. 1300 hours on the original spindles and belt. My gearbox has developed a small leak though.
henrysbe
l3400 woods bh80 backhoe post hole digger brush hog box blade rototiller
Jun 26, 2011
10
Sedro Woolley wa
Every time I mow tall grass, I have a problem of grass getting above the stump jumper, wrapping around the transmission shaft and getting into the seal. This can cause oil leakage so I would check oil level if you haven't yet. Does anyone have a solution for keeping tall grass from wrapping around the shaft? Every time this happens I have to remove the stump jumper, the 4 bolts holding the transmission in and then replace the seal. Is there a brush hog not prone to this?
hodge
Nov 19, 2010
2,954
517
Love, VA
^This^- your gearbox should be filled part way up, not full. It should have a breather, but extra oil isn't helpful.
Gearboxes generate heat- that's why they make baffled differential covers (to dissipate heat), and NASCAR cars have gear oil pumps to circulate and cool the oil in the rear axles. Don't be alarmed about that. But, it would be good to keep the grass clippings clear- to allow the gearbox to cool properly, and keep the small chance of a fire, a non-issue.
8,590
I would try smaller bites. Either mow more often, or multiple passes, one with the cutter high, then a second pass to knock it the desired height.
I've been in grass taller then my tractor with my rotary cutter. I go super slow and take two passes to knock it down to the level I want.
Southernfarm
2014 BX25D
Jun 8, 2016
109
Southern MB
Yes I was aware of the drain bolt, then the fill level bolt above it, and the fill bolt at the top and to fill until it comes out the second bolt.
As the deck is on its first season from new, when I take it out of service for the winter, I plan on changing the gearbox oil. Should I use the 75W-90 gear oil or should I use HST / UDT oil like I did with the front axle?
hodge
Nov 19, 2010
2,954
517
Love, VA
What does your owners manual say? Don't want to void any warranties.
