After seeing Kubota's Auxiliary light kit (which contains 1 light) for almost 300 bucks I wasnt overly impressed. So i decided to build my own which has 4 48w LED's and each one shoots out 3550 lumens. I custom made the brackets out of 1/4" aluminum and painted to match the ROP's, made the wiring harness with 10mm heat shrink tubing (to fit 4 14 gage wires through) along with two relays and a seven pin on-off-on rocker switch (forward position operates front lights and the rear position operates all light).... I think it came out good what do you guys think???
