L3901 Auxiliary LED light project
mikeslater
14
US
After seeing Kubota's Auxiliary light kit (which contains 1 light) for almost 300 bucks I wasnt overly impressed. So i decided to build my own which has 4 48w LED's and each one shoots out 3550 lumens. I custom made the brackets out of 1/4" aluminum and painted to match the ROP's, made the wiring harness with 10mm heat shrink tubing (to fit 4 14 gage wires through) along with two relays and a seven pin on-off-on rocker switch (forward position operates front lights and the rear position operates all light).... I think it came out good what do you guys think???
3,809
Very nice set up, you will be supper happy this winter
Deaner70
L3301, LA525 loader with QA, LAnd Pride RCR1860 hog
Aug 26, 2015
53
Shreve, OH
Did you use the spots or flood pattern?
Where did you get the switch? Very nice setup
mikeslater
14
US
I used flood pattern and I bought the switch h through Amazon.com just search 7 pin rocker switch and a rocker switch holder
Sent from my SM-T530NU using Tapatalk
stano
24
Ontario
Great install! I like the fact the button looks factory. Any chance you would be interested in putting a simple wiring schematic together? I understand the use of relays (for the most part) but I'm not sure where you tied into the existing wiring. I also have an L3901. I added an LED light bar but at this point it's just tied to the battery and requires me to remember to shut it off to not kill the battery.
RedTailHawk
46
Capon Bridge, WV
Isn't there an accessory plug/harness somewhere in the rear of the Kubotas? I thought one of the "LED worklight" threads pointed out an easy place to plug in your wiring harness to get switched power. (However, I can't find that thread again, and I can't locate the rear accessory power on my L3430).
Dhunt4work
L3800DT
Dec 24, 2014
35
Roanoke, Indiana
There is a worklight plug-in under the left rear fender of my L3800 DT you can actually plug quarter inch wide flat spade into each And pull your power from there. I am actually in process of doing a light project as well.
gregger
75
Saint John, NB Canada
Good job.
The price of the LED Light units have really come down within the last year, when building my cab recently, I bought all mine on Amazon.ca, the 5" square ones with 9 diodes were $44.00 for TWO, the smaller oval side lights with 6 diodes were $38.00 for two, and my center 14" light bar was $79.00
And the lighting capacity is amazing.
-Greg
mikeslater
14
US
There is a plug for auxiliary lighting on the L3901 but it only uses a 10 amp fuse so to use that would limit the lighting wattage
stano
24
Ontario
I found the plug thanks! I am going to run this power to a relay to provide power direct from the battery.
rkidd
Dec 7, 2015
742
67
Jefferson Ohio
Nice looking install. you will find them to be very useful when using your loader at night. You will be able to see your bucket level indicator which you can not with just the headlights. I used mine a lot on my B2650 this last week with all the snow we got here in NE Ohio and worked great.
thedevilyoulove
L3901 HST with LA525 FEL, Land Pride RCF2572, pallet forks, 3 pt carry all
Jan 27, 2016
143
Woodbine, Maryland
You did a great job!
I just ordered the factory Kubota rear light kit but it was $85. It only has one light, but I like that the light has a switch built into the back and it plugs right into the plug under the left fender. It's a clean installation at a reasonable cost, so I went with it. Certainly not a much light as your set up though.
