B2320 Tire chains
joeymon1
B2320 DT
Oct 1, 2015
Bath, NY USA
Does anyone run chains on this tractor without wheel extenders.
I have the 12-16.5 R4s on the rear and there is slightly less than 2 in of clearance between the sidewall and the fender. Tires are not loaded. My dealer is no help. Kubota says we don't sell chains, check with a chain vendor. Chain vendor says give them a bunch of measurements and maybe they can make a chain that will fit.
I expect this is a pretty popular tractor and someone must run chains in the winter without extenders.
Help!
3,092
Help!
joey,
lots of places to get chains:
http://www.tirechain.com/12-16.5tractor.htm
keep em tight! and also - load them thar tire if you can - but increase traction big time!
joeymon1
B2320 DT
Oct 1, 2015
Bath, NY USA
That's where I was looking. They tell me that I don't have the clearance for the recommended 3/8 chain for my tires.
I was hoping someone on the forum with my set-up has a chain that works. I would order that same chain. Even a truck chain with smaller links would help. To my knowledge they don't make smaller link chains to fit my tires.
pawaitejr
B2620HSD, FEL, 54"MMM, 5' Rear Blade, 5' Rock Rake, 72" Snowplow
Mar 13, 2014
Newburgh, New York
Joey, Your tires 12-16.5 R4 at Miller Tire have a Dia, of 32.7" and Width of 12.2"
My tires (B2620) are 33-12.5x15 turf with a Dia. of 33.8" with of 12.8" and are very close.
I use Peerless truck chains #322930 with no problems with clearance.
Just bought a second set to make up a set of 2 link.
Bought though Walmart for @65.00 shipped to house, but I just checked and they are out of stock.
BAP
Dec 31, 2012
3,209
1,320
Try this place. I have a set like this on my B2920 with the 33x12.5-15 turf tires and they fit fine and work good. They are basically a glorified garden tractor tire chain so the chain links aren't as heavy as the ones from Tirechain.com, which makes them fit better in the tight space. Mine are the 2 link and work well. They stay on well and are fairly easy to put on and take off.
http://www.tirechainsrus.com/garden-tractor-tire-chains-2-link.html
joeymon1
B2320 DT
Oct 1, 2015
Bath, NY USA
After a lot of research and thought, maybe spacers are the way to go. Should be able to install them myself.
that should improve stability and get my clearance
