B7800
jjmcm4858
6 Woodsend ave Shelton ct
Just removed bradco hoe ( 3375 hydraulic driven sub frame mounted) to install 3 point ( pto driven ) post hole. Need skematic for hydraulics?? Not sure which line goes where. 3 point and loader work but not forward/ reverse travel. Other hose set-up loader and traverse good but 3 point would not go up or down. . Very green at this. Thanks. James.
Billdog350
Kubota L3710 HST,L2230A QT,forks,Takeuchi TB125, 60" Luck Now pto Snowblower
Jan 6, 2014
468
11
East Hampton, CT
Take a picture of the setup on your machine esp where it is plumbed into your system so we can help.
8,717
I'll second the pictures request.
If there was 2 lines that went to and from the backhoe then you will need to loop those two lines together.
I don't know exactly why it would effect the HST, maybe they did something odd with a suction line setup. :confused:
jjmcm4858
After all that I must have gotten off machine and bumped range lever into neutral. First time taking hoe off so I was distracted and didn't notice. Silly mistake. Thank you so very much trying to help me. I usually never ask for help. Thanks again.
