B7100 fluid
malador
Old B7100
Jun 16, 2010
Pacfic Northwest
A friend of mine recently inherited 20 acres and an old Kubota b7100 (at least 28 years old). He asked me to take a look at it and see if i could get it running for him. After a new battery and ignition switch it started right up.
Now for the questions, what else does it need?
Is ISO 32 ok for replacing the hydraulic fluid?
Is 15-40 ok for the motor oil?
is 80-90 ok for the differentials?
what does the transmission take?
Any other maintenance that should be done?
thanks!
MDsteve
B7100, L225, L295DT
Jun 30, 2010
38
Forest Hill, MD
If it is an older gear drive B7100, then Tx and hydraulic fluids are the same. Use Kubota UDT or one of the Universal tractor hydraulic fluids (most will indicate compatibility with Kubota UDT). I've been using Kubota 10W30 engine oil for years and it's good for most weather.
bcapon
B7100HST-D
May 11, 2016
pownal, vt
Hello, I am new to this so I apologize for the lack of knowledge, but that is why I am here!
I have a B7100 HST that has a fluid leak, it appears to maybe be coming from the hydraulic control lever (right side of seat) and it drips down around the right side of the rear diff. This makes it a bit hard to tell if the leak is coming from the hydraulics (control lever) or the trans (rear diff right side seal).
Im looking for some clarification on the following, is the hydraulic system separate from the trans fluid system? I know that the rear diff and trans are the same system and use the same fluid, same fill and drain plugs, does this also apply to the hydraulic system or does the hydraulic system have its own fill, drain plugs and filter?
Thank you for any help!
-Bill
JBjunior
L35 TLB
Jun 16, 2011
26
SE, NC
-Bill
Bill,
On the HST the system is all one. On the left hand side near the bottom of the case is the suction and filter for the HST, on the right hand side is the suction and filter for the "hydraulic system." The part that you are talking about is the supply for the 3 pt system. There is a copper washer on either side of the fitting. A replacement can be had from Advance Auto... I did it a few days ago.
bcapon
B7100HST-D
May 11, 2016
pownal, vt
Great thank you!
So I should be all set if I do the following?:
1) Replace Trans fluid filter
2) Replace screen for "hydraulic" system
3) replace the copper crush washer
4) Fill with UTD
Also could you clarify what you are referring to by the "suction"? If I fill from the "Transmission Fill Port" (listed in the manual) it will fill the whole system, or are there multiple areas I need to fill from to replenish the fluid in the system?
Thank you very much for your help!
2,823
Great thank you!
4) Fill with UTD
filter, dont replace the screen, clean it well - unless it is somehow is really mess up (unlikely)...... replace washer too if need be.
One place to fill.
JBjunior
L35 TLB
Jun 16, 2011
26
SE, NC
Great thank you!
4) Fill with UTD
By suction, I mean from the sump to the pump.
bcapon
B7100HST-D
May 11, 2016
pownal, vt
Awesome thank you! Anyone have any insight to what the leak might be? hard to tell, i am going to clean the whole area and try to isolate where it is coming from. But if someone knows a trend with this tractor maybe it will help me focus in on something?
JBjunior
L35 TLB
Jun 16, 2011
26
SE, NC
I must not have been clear, I bet it is coming from the lever and that is where the washers go. As you pointed out, the leak will run down and that is likely since it is on a pressure line. A leak from a suction line will be a slow drip, a pressure line will either be a more forceful drip or a spray.
Mine was leaking there the other day....
