Grouse Feathers
BX2370, FEL, Snowblower-BX5455, Homebuilt Forks, LP RB1560, LP GS1548
I was looking at the fuel cutoff today so I would know how to stop the engine if the solenoid failed. That brought up a question. When you turn the key to off the electric fuel pump stops. Does the BX diesel require the electric fuel pump to continue running? Does the electric fuel pump just provide fuel to the injector pump for startups? I thought stopping the fuel pump would stop the engine, but I read that blowing the ignition fuse would require manually operating the fuel cutoff to stop the engine.
For anyone who hasn't looked for the fuel cutoff, the phillips head screw at the bottom of the picture is on the lever that operates the cutoff. You push the screw to the right and hold it until the engine stops.
